Emax
So I bought an emax rack (SE plus?)
2010-10-01 by pr_simon
Hello there, first post,
Just purchased an Emax SE rack, and couldn't find the answers to my first interrogations here. Besides the manual seems to assume one understands many "basics" that maybe I do not.
the back sticker says Model 2120 and the unit bears a blue SCSI connector on the right of the outputs. Well it's a DB-25 connector but there's no scripted "SCSI" on the back Panel. It does seem to have always been there though. On the inside board, the port is conected to "CN1"
Does all that make it a Plus version?
If it is, I'm a bit confused because this one came with a IDE ZIP 100 Drive, enclosed in an external case with power supply, that is connected through a flat scsi ribbon cable, going straight to the inside CN2 connector by the interstice a the base of the enclosure, thus avoiding the scary slot building operation described in the emulator archive website.
So, If the Emax has a built in ext SCSI connected to CN1, how comme the user decided to go for a more complicated procedure while he could have connected a regular external zip drive to that blue connector?
I can't believe that it is only because this was the only zip drive he had for exemple...
If I get a regular external zip drive, will it work on the supposedly factory scsi connector?
Now for the second problem.
The emax boots without a problem from the zip drive with the already loaded ZIPs I got and so far I can listen to the sound and edit them. On the other hand it doesn't seem to notice the also loaded floppy disks I insert in the regular drive, which I guess can be a real problem if I wich to use a different OS or more importantly format new disks/ZIPs.
I tried with the emax already booted, with the ZIP drive turned off, with the zip drive completely disconnected (in case you can't use both at the same time)... The only thing the emax says is "diagnostics" for a few seconds when turned on without the zip, then gets stuck on  "loading software" in all cases. Wether I try to insert a disk or remove a disk, nothing changes (though I can hear the floppy drive turn).
Any Idea on that as well?
Hope you can help
Thanks
Jeremie
Re: So I bought an emax rack (SE plus?)
2010-10-01 by alphabyte
Hi Jeremie,
First off, congratulations on your Emax purchase. I am quite certain once you get past these early growing pains you will be pleased.
The external DB25 connection is typical of Emax Plus units both factory made and upgraded. I can not make a direct correlation between what you are seeing internally vs what I have access to.
I have two Emax rack units. I have upgraded one to SCSI very recently. The internal 50-pin SCSI header on my board is CN2. The smaller CN1 header is the floppy drive connection.
I should clarify that my boards are pre SCSI. Significant modification was required to add SCSI to these units. Your machine may have a later board revision with different labeling and component locations. That being said, the floppy drive header should be near the edge of the board closest to the drive itself. It does sound like there are some strange things going on with the Zip drive, but, it works so you have that in your favor at the moment.
As for a standard, external SCSI Zip drive working with the DB25 connection, yes, this should work. The previous owner may not have been able to locate one. I use one from time to time with my Emax II keyboards. There is really no reason to have a janky drive hanging off the side of you Emax via a ribbon cable.
Based on your description, it would seem your board revision has two SCSI headers, a 25-pin to connect the external DB25 input and the standard 50-pin header for an internal drive. There should also be a standard hard drive power harness handing about inside as well.
As for the booting procedure, that all sounds rather normal with the exception of not recognizing the floppy drive. The "Diagnostics" period during bootup seems to be normal for SCSI/Plus units. I am basing this purely on my experience after upgrading my own machine.
It appears this period recognizes the presence of SCSI and allow time for the drives to spin up while the Emax determines what drives are present and where it should boot from. An internal or boot HD (Zip in your case) has to be set to SCSI ID 0.
The Emax can address a total of 36 danks. Bank 00 should be the floppy drive. When you click the "Load All" button, it should bring up the Bank selection screen. Choosing bank 00 should load the bank on the floppy disk you have inserted.
It sounds as though most everything is likely working as it should with the exception of the... creative... connection of the external Zip drive. I would suggest locating the SCSI documentation for the Emax if you do not already have it. This will help in understanding how the drives can be connected and properly navigating the OS along with moving from drive to drive.
The unit should boot from the floppy without the zip drive connected. Once the "Loading Software" screen appears, the Emax should have figured out that no hard drive is present and it should attempt to load from floppy.
Sometimes, my floppies don't seat properly in the drive. This mostly occurs with cheap disks that have flimsy plastic casing. When you insert the floppy, you should the the disk positively engage with the drive and drop slightly below the insertion slot. I usually resolve this issue by reinserting the disk a couple of times, with slight additional force. Don't be too rough. The drives are old and can be a bit on the sticky side with years of dust and neglect.
It would be helpful to know what OS version you are running off of the Zip drive, the floppies as well once you are able to get the unit to boot from the a floppy.
Keep us up to date and we can try to help as best we can.
Trevor
Wow, I do not mean to pollute everyone's mailbox but before i even read and study the whole thing later, thanks a lot for so many details!
--- In emax@yahoogroups.com, "alphabyte" <alphabyte@...> wrote:
> Hi Jeremie,
> Cheers,
> Trevor
2010-10-01 by esynthesist
Hi
The fact that the Emax doesn't boot from floppy may be caused by the age of the floppy drive. I have some samplers in which I have to insert and eject disks a few times before the drive's heads actually start reading the disks...
The reason why the ZIP is not connected to the external connector is probably because the previous owner did have a SCSI internal ribbon cable for connection to the IDE/SCSI adapter board within the ZIP external case but not an adapter for transforming it into a SCSI DB25 external terminal.
The fact that it is an internal ZIP (either IDE or SCSI) built into an external case with power supply, instead of a normal external SCSI ZIP drive, is probably because the owner wanted to be able to boot from the ZIP drive. With standard external SCSI ZIP drives this is not possible because they can only be set to SCSI ID 5 or 6, while SCSI ID 0 is required for a bootable HD in the Emax - as alphabyte already mentioned.
PS: I have an original Emax SE PLUS rack with PC333 rev board (the most recent CPU board); even on that board CN1 is the internal SCSI header and CN2 the floppy connector. But don't rely too much on these specs, because on the other hand my Emax Rack did not have a factory external SCSI DB25 connector, which is - according to all known E-Mu specs - simply impossible for a unit containing a PC333 board :-) The serial number is 0002 though - so it's probably a prototype unit.
///E-Synthesist
> --- In emax@yahoogroups.com, "alphabyte" <alphabyte@> wrote:
> > Hi Jeremie,
> > Cheers,
> > Trevor
2010-10-04 by alphabyte
Upgrading a rack unit required a new bottom panel.
Any luck getting the floppy to work?
--- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote:
> Hi
> ///E-Synthesist
> > > Hi Jeremie,
> > > Cheers,
> > > Trevor
2010-10-04 by pr_simon
Your two approaches were both enlightening thanks.
I finally managed to make the floppy work.
the previous owner had told me something like "the floppy is useless with the zip connected", perhaps he meant that the zip this way connected byspasses the floppy... Do think this is possible? However awkward, experience proved him right:
I disconnected the ZIP completely, including the ribbon cable and the floppy finally worked indeed. Perhaps it was a coincidence due to repeating attempts as suggested by Esynthesist. I haven't tried reconnecting the zip since then anyway.
It happens to be quite noisy with its power supply's fan, so I'd rather boot from a floppy and then enjoy a quieter external zip.
Phase 2: I located one instantly but once connected, the proceedure to select it as explained in the Emax SCSI istructions addendum did not work as stated, holding the transpose button did not give me access to the SCSI menu, only the... transpose menu, so I couldn't get it recognized.
My conclusion is that, although the emax is a plus (also with that 333 PCB by the way), none of my floppies carries the plus OS.
So I ordered one from route66 and we'll see if that works, unless you have other suggestions in the meantime.
Anyway, at the same time I was silly enough to try and replace the backlight myself, with limited soldering skills, but it turned out to be a tricky part when I put it back together.
I could see the light but needed to hold firmly the LCD so that it shows the entire display. This final operation resulted in some kind of short circuit. Now the LCD is messed up as a whole: light is gone for good, display shows partly, only when corners are firmly pressed and there's a permanent high bip at a noticeable volume, of which the pitch changes when you touch one of the backlight's contacts or the dedicated contacts on the panel PCB...
I guess i'm in for a repair fee and the delay that comes with it.
Don't try this at home...
> --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote:
> > Hi
> > ///E-Synthesist
> > > > Hi Jeremie,
> > > > Cheers,
> > > > Trevor
By the way, here are a couple photographs taken by the previous owner so you can see the "curiosities" I was mentionning earlier :
http://www.flickr.com/photos/35581041@N00/sets/72157624323467422/
> > > Hi
> > > ///E-Synthesist
> > > > > Hi Jeremie,
> > > > > Cheers,
> > > > > Trevor
2010-10-12 by alphabyte
Hey Jeremie,
I'm glad to hear you have been able to get the floppy up and running. If you have access to a PC capable of running EMX, you can create your own Plus OS disks. It's a bit of a hassle if you don't have an older machine with an earlier version of Windows or DOS even, but an option nonetheless.
I am sorry to hear about the problem with replacing the backlight. Usually, you can just desolder the backlight terminals and slide out the old one without much fuss. I have two Emax rack units. One, so far, I am keeping virgin. The other, I have added SCSI to and will be making additional modifications such as the external "Plus" SCSI port.
One of the mods I have completed is the addition of a Noritake VF Display. These are intended to be direct LCD replacements and require no additional power. Works really well and no more concern about backlights. It exhibits very small flickering during some navigation operations, but, I am very pleased with the mod.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=286-1068-ND
Some photos after the mod:
http://www.flickr.com/photos/52975669@N06/sets/72157625151557158/
It is a direct one-for-one pin correlation to the stock display. It takes a bit of work to wire it up. I just soldered wires to it to make sure it would work, but they are a bit too heavy a gauge and the fit is tight. You also have to work out a mounting solution. I just matched up one of the mounting holes with a blank space in the front panel board and drilled a hole. I will be adding a proper header and ribbon connection as soon as I have all of the parts.
You may not like the aesthetics, but it is a very nice solution if you just need to use the thing. I will be experimenting with different opamps next. I have socketed the dual (stereo) output chip already and tried an alternate I had on hand. I will be researching and order some other chips to try out. Very interesting and fun. I have learned a lot about the unit digging around in its guts the last couple of weeks.
At any rate, I hope this info is helpful. Best of luck with your Emax.
2010-10-21 by pr_simon
Thanks a lot, and sorry for not replying, I do not receive updates so it is whenever I visit the group...
I actually find this display gorgeous! So I'm almost sold on doing the replacement, although perhaps not myself this time... I honestly do not have the technical knowledge to mess around any further.
Still concerned by the whining on mine after trying the backlight change, any idea if is a common trouble and fixable by just redoing the job properly?
Or is it more serious and something may have been damaged in the LCD's powering section on the board itself for exemple?
> Hey Jeremie,
RE: [emax] Re: So I bought an emax rack (SE plus?)
2010-10-21 by el macaco
Goddamn that display is nice!
Any chance that when you get all the proper headers and all you can list the parts and post a few pics for the less skilled and intrepid of us?
I'd love to do this but my display is fine, and I'd like to know if the mounting is secure once the headers are in.
You may also try velcro for mounting on the inside, holds tight and removed fairly easily and might fit behind the VFD to stick it to the front panel PCB.
Amazing work and thanks!
Ed
To: emax@yahoogroups.com
Date: Thu, 21 Oct 2010 13:45:51 +0000
Subject: [emax] Re: So I bought an emax rack (SE plus?)
> Hey Jeremie,
2010-10-21 by alphabyte
Hey Jeremie,
No worries. I don't receive updates either. That is why there is often a bit of time between my posts as well.
As for the whine you are hearing, it is not uncommon. In my experience, it is not too loud however. I have heard of cutting a piece of thin paperboard, such as from a matchbook, and inserting behind the backlight to dampen the oscillation.
I should stipulate that I am not a technician. I am just someone who likes taking things apart and figuring out how they work. I am in the process of learning about electronics, but, I am in no way qualified to tell you the right way to do anything of this nature.
I would agree having a tech service your display is the best way to go.
trevor
> > Hey Jeremie,
Hi Ed,
I will definitely post some photos once I have a permanent installation I am happy with.
On the rack unit, there is not enough clearance for velcro. I had a very intricately cut pice of perfboard that I planned to use for mounting, but misjudged the actual thickness of the stock display due to the connector pins. I had to scarp the pefboard and mount directly to the PCB.
I might look into fitting some screw mounts to the PCB with epoxy. Again, will require some research on my part. I have to look at the board again for placement and search for a PCB friendly epoxy.
I will keep you updated.
-trevor
> Ed
> From: pr_simon@...
> > Hey Jeremie,
Thanks, I have a rack unit as well.  I remember replacing the backlight, it does look tight in there!
I look forward to your success!
Date: Thu, 21 Oct 2010 19:47:45 +0000
Hi Ed,
-trevor
> Ed
> From: pr_simon@...
> > Hey Jeremie,
