Emax SE Rack and HxC Floopy Emulator Problem.
2011-02-07 by Javier
Hi everybody... Does anyone have the HxC SD reader/virual Floppy installed on an Emax 1? I installed mine on my Emax SE Rack and it seems to work ok (physically), but I think I´m doing something wrong regarding the OS or the card config. What I did so far is: 1)Downloaded diskette images from here: http://www.hermannseib.com/english/synths/emax/banks.htm 2)Opened the HxC software and converted some .EMX files to .HFE format into the SD memory. 3) went to http://emulatorarchive.com/Samplers/EmaxOverview/EmaxOS/emaxos.html And downloaded "emaxse11.zip", and extracted it. 4) Then I copied "emaxos.emx" into the same path (root) as the .HFE files in the SD memory stick. I don´t have my Emax here with me right now, but it seems to read the card but then it´s like it can´t find the OS. I tell it to load any image and it seems to be recognized by the HxC card, but the Emax begin loading and it hangs... What I´m doing wrong? What settings should I use on the HxC software? Any help will be appreciated! JZ:
