Emax
Re: [emax] emax memory issues
2011-02-16 by n_c630@yahoo.com
Any idea if this is possible? Or how to go about doing this?
----- Reply message -----
Date: Wed, Feb 16, 2011 3:13 pm
Subject: [emax] emax memory issues
To: <emax@yahoogroups.com>
You may have lost the eeprom programming.
This is the "scrambled megs" condition that people talk about.
Emu used to offer a service to fix this, but my understanding is they no
longer do so.....
My understanding also is that the disk is a one-time use and once you lose
the eeprom setting, you would have to re-program the eeprom.
Ted
On Wed, Feb 16, 2011 at 12:09 PM, n_c630 <n_c630@...> wrote:
> I have an emax 2 model 2213 that boots up to 1 meg but states that there is
> a memory issue. The unit came with the 2meg memory expansion disk. Opening
> it up it does seem to have the memory daughter board. Any reason that it may
> be only recognizing 1meg? Is it possible the board was not installed
> properly?
> Thanks!
http://www.silveriafamily.comYahoo! Groups Links
2011-02-16 by Ted Summers
You have to socket the eeprom.
Someone here on the group has the file and can make eeprom for this once you
socket it if you can't get a programmer.
The chip is cheap - like 50 cents.
Ted
> From: "Ted Summers" <djtbs1@...>
> longer do so.....
> Regards,
> Ted
> is
> Opening
> may
> > properly?
> > Thanks!
2011-02-17 by n_c630@yahoo.com
I guess i can start with trying to reseat the chips as that is something i can actually do.  Im assuming by 'socket' the eeprom that the original is sodered in ans id have to remove it and put in place one of those pieces that allows you to interchange chips?  Zipsocket?  Can see about checking psu levels too. My neighbor knows that stuff.
Thanks for the help!
Date: Wed, Feb 16, 2011 6:56 pm
2011-02-24 by n_c630@yahoo.com
So.  I reseated the memory chips on the daughterboard and put it back in place. Still only sees one meg.  If i were to test psu voltages can someone walk me thru it? I have a digital multimeter which im sure is capable....thanks!
