Help Emax II Rack sounds No preset No patch hard drive
2011-04-17 by Vavasseur Philippe
Hi I buy a rack emax 2 is that the bone on a hard drive no sounds I Floppies 720 DD 2 days I can not put sounds on floppy disks are a lot of programs available I manage to format the Floppies disk with XP sounds I can not place them on the Floppies disk and midi with a program that I receive not send I get to see the vacuum in the emax help what midi program ? what program to send the Floppies disks ? with what files .EM1 , .EM2 , .Img .EB2.................... I am in France thank you to explain to you understand thanks philippe
2011-04-18 by patrick.rebullida@...
Bonjour Philippe Je peux répondre à tes questions en français si ça t' interresse ... I can answer to you in french ... ----- Mail Original ----- De: "Vavasseur Philippe" <philippe.69@...> À: emax@yahoogroups.com Envoyé: Dimanche 17 Avril 2011 23h10:08 GMT +01:00 Amsterdam / Berlin / Berne / Rome / Stockholm / Vienne Objet: [emax] Help Emax II Rack sounds No preset No patch hard drive Hi I buy a rack emax 2 is that the bone on a hard drive no sounds I Floppies 720 DD 2 days I can not put sounds on floppy disks are a lot of programs available I manage to format the Floppies disk with XP sounds I can not place them on the Floppies disk and midi with a program that I receive not send I get to see the vacuum in the emax help what midi program ? what program to send the Floppies disks ? with what files .EM1 , .EM2 , .Img .EB2.................... I am in France thank you to explain to you understand thanks philippe
2011-04-18 by Ted Summers
Does it boot to the menu? If so, then you need to format a disk with the emax and then you can use EMXP or EMX UTIL to write a sound bank. If you have no boot floppy then you need to use a PC and perhaps EMAXUTIL to write an OS image. From there you should be able to write a sound bank from the images on the group and use that as a starting point. Regards, Ted On Sun, Apr 17, 2011 at 5:10 PM, Vavasseur Philippe <philippe.69@...>wrote: > > > Hi I buy a rack emax 2 is that the bone on a hard drive no sounds > I Floppies 720 DD 2 days I can not put sounds on floppy disks > are a lot of programs available I manage to format the Floppies disk with > XP > sounds I can not place them on the Floppies disk > and midi with a program that I receive not send I get to see the vacuum in > the emax > help > > what midi program ? what program to send the Floppies disks ? with what > files .EM1 , .EM2 , .Img .EB2.................... > > I am in France thank you to explain to you understand > thanks > philippe > > > [Non-text portions of this message have been removed]
2011-04-18 by Vavasseur Philippe
en français super --- In emax@yahoogroups.com, patrick.rebullida@... wrote:
> > Bonjour Philippe > > Je peux répondre à tes questions en français si ça t' interresse ... > I can answer to you in french ... > > > ----- Mail Original ----- > De: "Vavasseur Philippe" <philippe.69@...> > Ã: emax@yahoogroups.com > Envoyé: Dimanche 17 Avril 2011 23h10:08 GMT +01:00 Amsterdam / Berlin / Berne / Rome / Stockholm / Vienne > Objet: [emax] Help Emax II Rack sounds No preset No patch hard drive > > > > > > > Hi I buy a rack emax 2 is that the bone on a hard drive no sounds > I Floppies 720 DD 2 days I can not put sounds on floppy disks > are a lot of programs available I manage to format the Floppies disk with XP > sounds I can not place them on the Floppies disk > and midi with a program that I receive not send I get to see the vacuum in the emax > help > > what midi program ? what program to send the Floppies disks ? with what files .EM1 , .EM2 , .Img .EB2.................... > > I am in France thank you to explain to you understand > thanks > philippe >
Quelles sont tes questions ? quelle est ta machine ? quelles sont les caracteristiques ? Pour commencer , il faut que tu formates des diskettes dans ton emax Après, un fois le prog EXMP installé sur ton pc , et le driver OmniFlop installé , tu pourras recopier des images EM1 ou EM2 ou des banks de sons de ton pc vers cette disquette. Ensuite tu mets la disquette dans l'emax ,et tu démarres la machine avec . (Tu peux aussi formater les disquettes via le logiciel EXMP) ci joint le lien http://users.skynet.be/emxp/ n" hésite pas à me contacter Patrick ----- Mail Original ----- De: "Vavasseur Philippe" <philippe.69@...> À: emax@yahoogroups.com Envoyé: Lundi 18 Avril 2011 15h12:31 GMT +01:00 Amsterdam / Berlin / Berne / Rome / Stockholm / Vienne Objet: [emax] Re: Help Emax II Rack sounds No preset No patch hard drive en français super --- In emax@yahoogroups.com , patrick.rebullida@... wrote:
> > Bonjour Philippe > > Je peux répondre à tes questions en français si ça t' interresse ... > I can answer to you in french ... > > > ----- Mail Original ----- > De: "Vavasseur Philippe" <philippe.69@...> > À: emax@yahoogroups.com > Envoyé: Dimanche 17 Avril 2011 23h10:08 GMT +01:00 Amsterdam / Berlin / Berne / Rome / Stockholm / Vienne > Objet: [emax] Help Emax II Rack sounds No preset No patch hard drive > > > > > > > Hi I buy a rack emax 2 is that the bone on a hard drive no sounds > I Floppies 720 DD 2 days I can not put sounds on floppy disks > are a lot of programs available I manage to format the Floppies disk with XP > sounds I can not place them on the Floppies disk > and midi with a program that I receive not send I get to see the vacuum in the emax > help > > what midi program ? what program to send the Floppies disks ? with what files .EM1 , .EM2 , .Img .EB2.................... > > I am in France thank you to explain to you understand > thanks > philippe >
2011-04-19 by Vavasseur Philippe
I have a problem with the audio board a regulator just burned reparere I wait for the moment I come back here when AC working again thank you for responding --- In emax@yahoogroups.com, patrick.rebullida@... wrote:
thank you for responding I wait for the audio board that you want to sell you saved my life thank you very much philippe.69@... --- In emax@yahoogroups.com, Ted Summers <djtbs1@...> wrote:
> > Does it boot to the menu? If so, then you need to format a disk with the > emax and then you can use EMXP or EMX UTIL to write a sound bank. > > If you have no boot floppy then you need to use a PC and perhaps EMAXUTIL to > write an OS image. > From there you should be able to write a sound bank from the images on the > group and use that as a starting point. > > Regards, > Ted > > > > On Sun, Apr 17, 2011 at 5:10 PM, Vavasseur Philippe <philippe.69@...>wrote: > > > > > > > Hi I buy a rack emax 2 is that the bone on a hard drive no sounds > > I Floppies 720 DD 2 days I can not put sounds on floppy disks > > are a lot of programs available I manage to format the Floppies disk with > > XP > > sounds I can not place them on the Floppies disk > > and midi with a program that I receive not send I get to see the vacuum in > > the emax > > help > > > > what midi program ? what program to send the Floppies disks ? with what > > files .EM1 , .EM2 , .Img .EB2.................... > > > > I am in France thank you to explain to you understand > > thanks > > philippe > > > > > > > > > [Non-text portions of this message have been removed] >
