Emax
formatting an SD or CF card?
2012-02-13 by soundsubs
hello again group-
in a day or so i hope to convert my baldwin ike to one with an SD card reader as i purchased the pcd-50b and a ton of scsi chips.
to my question:
i have about 43.5 mb worth of sample banks. i would like to put these on a partition(s) and "lock" them if possible to only be read, not written. kind of like a ROM bank of sounds. but im not sure i can have more than one formatted drive on a removeable media.
i would also like to have a part of the removeable media which i can store my own samples.
is there any way to do this?
if so, what is the best way to do this?
i understand that the emax might not be able to format/read greater than 20mb at a time. i cant find where i read that though.
what would you do?
Re: [emax] formatting an SD or CF card?
2012-02-13 by Ted Summers
1) just click the write protect tab on the media.
2) you can't have more than one "partition" on the media
3) Emax 1 can only format 20MB due to firmware restriction of the Emax
4) Where you want to write your samples on a removable media, that would
need to be a media that is not locked as per 1.
I don't believe you can protect single "banks".
Once you have a media and it has the banks, make a copy with EMXP and play
with the duplicate.
I have like 10 flash I bought to do same....
On Mon, Feb 13, 2012 at 2:43 PM, soundsubs <soundsubs@...> wrote:
> hello again group-
> to my question:
> my own samples.
> what would you do?
2012-02-14 by jammie
you can only use the pcmcia slot with the emax
cf cards are best sd seem to curupt easily
  To: emax@yahoogroups.com
  Sent: Monday, February 13, 2012 10:43 PM
  Subject: [emax] formatting an SD or CF card?
  hello again group-
  to my question:
  what would you do?
Re: formatting an SD or CF card?
2012-02-14 by soundsubs
ARGH!
now i have to buy a pcmcia-to-sd card converter to go in it?
sheesh. this is getting insane.
Re: [emax] Re: formatting an SD or CF card?
the cf cards are best sd cards seem to curupt
you can try any way its your choice
but cf cards are very close to the ata standard and the pcmcia slot is an ata device
  Sent: Tuesday, February 14, 2012 2:45 PM
  Subject: [emax] Re: formatting an SD or CF card?
  ARGH!
Yup, I know that part.
...but i bought the PCD-50b drive.
it has a PCMCIA, CompactFlash, MemoryStick, SD/MMC, and Smartmedia slots.
are you saying that only the PCMCIA slot works with the emax because of LUN?
2012-02-14 by Nik Kinloch
Yes.
yes it will only work on lun 0 which is the ata device pcmcia16bit card slot
as the emax is scsi version 1 before lun support came out thats a scsiII protocol and it has to have the bios for it
it was used for servers so that they could access cdroms more than just 1 so they deviced a lun standard so that 8 cdrom drives could be accessed
but no sampler has ever supported it only computer os
  Sent: Tuesday, February 14, 2012 3:51 PM
