Emax
CF cards for Emax II
2012-11-11 by Tony Court
Does anyone have any recommendations for currently available working CF cards that will work with a PCD-50B installed in an Emax II?
I have tried formatting the one I received with the PMCIA-CF converter card and it sits verifying for several hours, but I can never seem to boot from it when the operation completes.
Tony
Re: [emax] CF cards for Emax II
2012-11-11 by jammie
dont use the transcend they are buggy
sandisk 512mb is good to go i use these in the EIII emax1/2
with the upgrades i fit for customers
also have you set up the pcd-50b correctly as they are set to scsi ido and they have to be set to scsi id1 for it to boot from the cf card
  To: emax@yahoogroups.com
  Sent: Sunday, November 11, 2012 7:02 AM
  Subject: [emax] CF cards for Emax II
  Tony
Hi Jammie, that may explain it. I originally had the internal HD as the boot device. I had the PCD set to scsi 2.
Will reset jumpers and hopefully that will fix things :)
Thanks
Tony
> From: Tony Court
> Tony
Re: CF cards for Emax II
2012-11-11 by dwv1957
Actually, the EmaxII can boot from any device, you just have to tell it which one.
Go to Master 9-Special > 6-SCSI Boot ID
If there is no boot device at the selected ID, then the Emax will scan the SCSI buss, and boot from the first device it finds.
For example, if the EmaxII is set to boot from SCSI ID 5 and there is no device there, but you do have bootable devices on ID's 2&4, it will boot from ID 2.
Hope this helps
Dave
> Thanks
> Tony
> > From: Tony Court
> > Tony
