Hi Ted, I appreciate your support, I'll do right now! Greetings!
Daeron...
De: Ted Summers <djtbs1@gmail.com>
Para: emax@yahoogroups.com
Enviado: Domingo, 10 de febrero, 2013 2:29:24
Asunto: Re: [emax] Help to fix EMAX SE
Reseat EPROM IC 13 and check display ribbon cable for the display showing black boxes….
Verify good connection between floppy drive.
The floppy drive may have gone bad.
It is also possible that if it was misconnected that it ruined the format on the disk you are trying, so try a couple different disks with the Emax2 drive in the Emax 1….
Ted
On Feb 9, 2013, at 11:29 PM, Daeron wrote:
Hi!
A few days ago i get an EMAX SE but to turns on and insert the os disk is displayed "disk not formated" sometimes appear black boxes on the display in high contrast and the screen freezes, i used all OS versions in new floppy dd disks but the problem continues!
any advice to fix it?
motherboard says REV C and Model 1000
I put the floppy drive of my emax II but it's the same problem!
has solution for a problem like this?
I appreciate any tips that might help!
Greetings!
http://www.silveriafamily.comYahoo! Groups Links
