Emax
Emax 1 - white noise
2013-03-12 by geri.echue
I own a standard emax 1 rackmount, not an SE or a HD. When I purchased the machine it came with a number of floppy disks. Everything seemed to be working fine until I entered an emax SE upgrade disk which had a label on 'upgrade disc use once only'.
Since then, the sounds on certain disks have an added high frequency hiss/white noise on top of them.
Also when I try and sample any audio into it, the same added hiss occurs on top of my audio.
Since then, certain disks loaded with synths samples work without the white noise but I've tried copying these onto a blank disk and deleting the samples, and then recording audio into it, but it still adds the noise on top of it.
I tried putting operating systems (that are compatible with the emax 1) on an emax formatted disk using OMIFLOP and EMXP program. When some of these are put in the emax, they load up but the display reads 'bad bank data'. With other operating systems, they load up fine, but still the white noise occurs on top of samples/ or when recording audio.
Someone told me, that if you can filter out the high frequency sound with the low pass filter, which i can, means there is nothing wrong with the machine, you've just corrupted your disks/samples.
What I think I've done, is that when I put the upgrade disk in, this put the SE Upgrade on for the second time. As since then I can't record any audio without white noise.
This is driving me crazy, could anyone help?
Geri
Re: [emax] Emax 1 - white noise
2013-03-12 by Ted Summers
The SE update disk updates an 93C06 EEPROM with a couple of bits that
ENABLE the SE functionality.
It doesn't update the boot  EPROM firmware or change the menus, in of
itself.
Then there is the OS that is on the SE update disk.
This adds the SE functionality to the menus.
Where you are booting from a NON-SE disk, the SE enable is still in this
EEPROM, but you don't have any of the options in the OS...
Where a unit doesn't have SE, booting from the disk will tell you it is
updating the unit if it is a new disk.
It is a once use disk in that once a unit is updated, you cannnot use the
same disk to update another unit.
From there, the disk is usable to boot and has a sound bank to explore the
SE functions.
I have found no negative effects from using a new SE update disk on a unit
twice.... it would only rewrite the same bytes it already wrote- if
anything.
That is my experience / knowledge of it.
Thx,
Ted
PS- The only other thing that may be of note, is it may be useful to
recalibrate the machine booted from an SE capable OS disk and see if
anything changes.
> on top of my audio.
> top of it.
> Geri
Replacing LEDs in Emax rack?
2013-03-13 by Nik Kinloch
Hey all,
Has anyone replaced the LEDs in the Emax rack? Thinking of putting in
white LEDs instead of the red / green ones. I know that white LEDs may
need different voltage / current, but I'm wondering if low current ones
would work for the purposes of display? Any chance that it could damage
something experimenting with them?
Thanks!
Nik
Re: Emax 1 - white noise
2013-03-17 by geri.echue
Thanks for your reply, you said I could recalibrate the machine, how would I do this?
Geri
> itself.
> SE functions.
> anything.
> Thx,
> Ted
> anything changes.
> > on top of my audio.
> > top of it.
> > Geri
Re: [emax] Re: Emax 1 - white noise
2013-03-17 by Ted Summers
All the guides are here:
http://www.cyborgstudio.com/emax.html
check out the Emax Diagnostics
Geri
> itself.
> SE functions.
> anything.
> Thx,
> Ted
> anything changes.
> > on top of my audio.
> > top of it.
> > Geri
