Emax
Emax 2 scanning SCSI ID's - solution.
2013-06-13 by Ted Summers
My Emax 2 started doing this some time ago, so I finally decided to investigate this further.
what I found was that while my internal flash drive had termination on it, for whatever reason, it wasn't "good enough".
I removed the termination jumpers (term pwr and termination), then changed my cable to a 2 device cable.
On the last connector I added an ACTIVE terminator, and the scanning stopped, it booted from the SCSI immediately.
Just thought people would like to know what I found on this issue.
Ted
Re: [emax] Emax 2 scanning SCSI ID's - solution.
2013-06-13 by Scott Stanley
Nice catch Ted!  Could you please elaborate on how you added the active terminator?  I am not familiar with how to add termination on an internal SCSI cable without a device that has this option.
-Scott
> Regards,
> Ted
i changed the cable to a cable that has 1 more connector than I have devices (in this case, the cable has 3 connectors - 1 end to the board. middle to the device, other end, put on the terminator).
The terminator I used is similar to the following:
http://www.ebay.com/itm/IDC50-Male-Single-Ended-Active-SCSI-Terminator-/171055829136?pt=US_Drive_Cables_dapters&hash=item27d3b8d090
-T
-Scott
> Regards,
> Ted
