emax ii 2201 (emax 2) - zip 100 verifying forever
2013-06-26 by Matt
2013-06-26 by Matt
emax ii 2201 (emax 2) - zip 100 verifying forever cannot format zip 100 scsi everything works until verifying... forever and zip drive access light stays lit have tried: using 5 terminator on, 5 terminator off on both scsi and zip logo ports. i am not trying to use additional devices in the scsi chain at this time. is this indication of a bad drive or bad disk? [Non-text portions of this message have been removed]
2013-06-26 by Francis Cote
Hi Matt, I use a zip drive with it's terminator switch. Try another disk. On Jun 25, 2013 8:01 PM, "Matt" <somatt@...> wrote: > ** > > > emax ii 2201 (emax 2) - zip 100 verifying forever > cannot format zip 100 scsi > everything works until verifying... forever and zip drive access light > stays lit > have tried: using 5 terminator on, 5 terminator off on both scsi and zip > logo ports. i am not trying to use additional devices in the scsi chain at > this time. > is this indication of a bad drive or bad disk? > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2013-06-26 by Matt
Which port on the zip drive do u use? Scsi logo or zip? Do u use it terminate switch on? Does it work on 5 and on 6? Which end of the cable goes to the zip and which to the sampler? Cable says zip on one side, scsi logo on other side. On Jun 25, 2013 5:10 PM, "Francis Cote" <francis.cote@...> wrote: > Hi Matt, > > I use a zip drive with it's terminator switch. > Try another disk. > On Jun 25, 2013 8:01 PM, "Matt" <somatt@...> wrote: > > > ** > > > > > > emax ii 2201 (emax 2) - zip 100 verifying forever > > cannot format zip 100 scsi > > everything works until verifying... forever and zip drive access light > > stays lit > > have tried: using 5 terminator on, 5 terminator off on both scsi and zip > > logo ports. i am not trying to use additional devices in the scsi chain > at > > this time. > > is this indication of a bad drive or bad disk? > > > > [Non-text portions of this message have been removed] > > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > > [Non-text portions of this message have been removed]
My problem is that all my stuff is packed into a storage until the end of July and I am currently living in hell (in-law's basement)... But I'll do my best by memory... check my answers below. On Tue, Jun 25, 2013 at 9:03 PM, Matt <somatt@...> wrote: > ** > > > Which port on the zip drive do u use? Scsi logo or zip? > The SCSI logo is to extend the chain, if memory serves. So you connect the cable from Zip logo to the Emax scsi port. > Do u use it terminate switch on? Does it work on 5 and on 6? > I use the terminate switch on (the little 'I') and use scsi port 5. > Which end of the cable goes to the zip and which to the sampler? Cable says > zip on one side, scsi logo on other side. > It's just a guide, it shouldn't make any difference. > > On Jun 25, 2013 5:10 PM, "Francis Cote" <francis.cote@spadz.com> wrote: > > > Hi Matt, > > > > I use a zip drive with it's terminator switch. > > Try another disk. > > On Jun 25, 2013 8:01 PM, "Matt" <somatt@gmail.com> wrote: > > > > > ** > > > > > > > > > > emax ii 2201 (emax 2) - zip 100 verifying forever > > > cannot format zip 100 scsi > > > everything works until verifying... forever and zip drive access light > > > stays lit > > > have tried: using 5 terminator on, 5 terminator off on both scsi and > zip > > > logo ports. i am not trying to use additional devices in the scsi chain > > at > > > this time. > > > is this indication of a bad drive or bad disk? > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------------------ > > > > > Emax and Emax II User's Group Website > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2013-06-26 by Matt
Thanks so much! I will try that when I get home. -matt On Jun 25, 2013 6:15 PM, "Francis Cote" <francis.cote@...> wrote: > My problem is that all my stuff is packed into a storage until the end of > July and I am currently living in hell (in-law's basement)... > > But I'll do my best by memory... check my answers below. > > > On Tue, Jun 25, 2013 at 9:03 PM, Matt <somatt@...> wrote: > > > ** > > > > > > Which port on the zip drive do u use? Scsi logo or zip? > > > The SCSI logo is to extend the chain, if memory serves. So you connect the > cable from Zip logo to the Emax scsi port. > > > Do u use it terminate switch on? Does it work on 5 and on 6? > > > I use the terminate switch on (the little 'I') and use scsi port 5. > > > Which end of the cable goes to the zip and which to the sampler? Cable > says > > zip on one side, scsi logo on other side. > > > It's just a guide, it shouldn't make any difference. > > > > > On Jun 25, 2013 5:10 PM, "Francis Cote" <francis.cote@...> wrote: > > > > > Hi Matt, > > > > > > I use a zip drive with it's terminator switch. > > > Try another disk. > > > On Jun 25, 2013 8:01 PM, "Matt" <somatt@...> wrote: > > > > > > > ** > > > > > > > > > > > > > > emax ii 2201 (emax 2) - zip 100 verifying forever > > > > cannot format zip 100 scsi > > > > everything works until verifying... forever and zip drive access > light > > > > stays lit > > > > have tried: using 5 terminator on, 5 terminator off on both scsi and > > zip > > > > logo ports. i am not trying to use additional devices in the scsi > chain > > > at > > > > this time. > > > > is this indication of a bad drive or bad disk? > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > ------------------------------------ > > > > > > > > Emax and Emax II User's Group Website > > > > > > http://www.silveriafamily.comYahoo! Groups Links > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > > > [Non-text portions of this message have been removed]
2013-06-29 by dwv1957
The Emax does not care which address you use, 5 or 6, termination should be ON. The Emax will format the disk in a few seconds, but it can take up to an hour to verify the disk, so don't be in a hurry. It sounds like everything is working fine on your end, you are just not giving it enough time. Dave --- In emax@yahoogroups.com, Matt <somatt@...> wrote:
> > emax ii 2201 (emax 2) - zip 100 verifying forever > cannot format zip 100 scsi > everything works until verifying... forever and zip drive access light > stays lit > have tried: using 5 terminator on, 5 terminator off on both scsi and zip > logo ports. i am not trying to use additional devices in the scsi chain at > this time. > is this indication of a bad drive or bad disk? > > > [Non-text portions of this message have been removed] >
2013-06-29 by Matt
Thanks following your advice I was able to get it to work. I just gave it time to verify and all was well. -matt On Jun 28, 2013 8:03 PM, "dwv1957" <dwv1957@...> wrote: > ** > > > The Emax does not care which address you use, 5 or 6, termination should > be ON. > The Emax will format the disk in a few seconds, but it can take up to an > hour to verify the disk, so don't be in a hurry. > It sounds like everything is working fine on your end, you are just not > giving it enough time. > > Dave > > --- In emax@yahoogroups.com, Matt <somatt@...> wrote: > > > > emax ii 2201 (emax 2) - zip 100 verifying forever > > cannot format zip 100 scsi > > everything works until verifying... forever and zip drive access light > > stays lit > > have tried: using 5 terminator on, 5 terminator off on both scsi and zip > > logo ports. i am not trying to use additional devices in the scsi chain > at > > this time. > > is this indication of a bad drive or bad disk? > > > > > > [Non-text portions of this message have been removed] > > > > > [Non-text portions of this message have been removed]
