Emax
Emu Emax II Issue
Emu Emax II Issue
2013-08-16 by Patrick
I just purchased an emax II and every time I try to turn it on every single led constantly blinks and the machine makes a constant clicking noise. Anyone know what this could mean?
Patrick
Re: [emax] Emu Emax II Issue
2013-08-17 by umi4m@...
Sounds line a faulty power supply..
On Aug 16, 2013, at 4:17 PM, "Patrick" <nooblet12@...> wrote:
> Hi,
> Patrick
2013-08-17 by Ted Summers
Yes- Power supply is bad or bad connection at the connector of PS or power switch itself.
Don't let this go with power on too long- you could permanently damage the logic board as each "on" is coming through as a surge, most likely.
EPR Electronics sells direct replacement PS. Google them�
-T
On Aug 16, 2013, at 4:17 PM, "Patrick" <nooblet12@...m> wrote:
> Hi,
> Patrick
2013-08-17 by Daeron
Hi, I had the same problem and disconnect the internal hard drive and it worked normally!
Daeron...
 De: "umi4m@..." <umi4m@...>
Para: "emax@yahoogroups.com" <emax@yahoogroups.com>
Enviado: Viernes, 16 de agosto, 2013 19:57:54
Asunto: Re: [emax] Emu Emax II Issue
> Hi,
> Patrick
Re: Emu Emax II Issue
2013-08-17 by Mr. Shortwave
Is it an HD model or floppy only model?
--- In emax@yahoogroups.com, "Patrick" <nooblet12@...> wrote:
> Hi,
> Patrick
Daeron-
Either the control board on the HD was bad, causing a drain on the power supply, or  your power supply is weak and nearing end of it's life.
did you try and hook some other hard drive to the power supply to see if it was the same behavior?
If so- I would still replace that power supply�.as it is running on borrowed time. :-(
-Ted
Daeron...
> Hi,
> Patrick
2013-08-17 by scioto123
I had read that Mendelsons in Dayton Ohio had the power supply for an Emax II. I live about 45 minutes away from there and they buy over stock, electronic components and old computer parts from companies that went under. The warehouse is 4 stories and you can walk around and look through the bins. Place has everything including and Web site so you can order on line. If It hard to find or just something you look at and say "who would want that?"they have it.
> -T
> > Hi,
> > Patrick
Re: [emax] Re: Emu Emax II Issue
I would like to look into this for possible spares.
What is the website link?
Thx,
Ted
> -T
> > Hi,
> > Patrick
Its www.meci.com and if you live close enough and dont see it on their website its worth the time to go look around. I see something new every time I go. Place is great.
Sent from my Samsung Galaxy Note® II
-------- Original message --------
Date: 08/17/2013  11:37 AM  (GMT-05:00)
To: emax@yahoogroups.com
Subject: Re: [emax] Re: Emu Emax II Issue
Thx,
Ted
> -T
> > Hi,
> > Patrick
http://www.silveriafamily.comYahoo! Groups Links
