Main Emax Right/Mono Output Noisy
2013-10-13 by Nik Kinloch
Hi all, I have been spending some time working on cleaning up my Emax outputs. First thing I did which was a success was to remove the unneeded backlight driver - this totally cured a whine coming from the outputs. After removing that, I then noticed some standard basic noise coming from only the Right/Mono output. I did a lot of testing to make sure it was the output, including switching desk channels, switching cables, and even switching the whole output board out for another one (I have a spare Emax). The noise was always the same, and always out of the same output. Ok, so I looked at the schematic, and saw the L and R output circuitry is different. This is to provide the summed mono output if only one lead is connected. So, I figured I'd just mod the circuit so they were both the same. I lifted R39 at the IC40 pin 3 end. I lifted R33 at the IC40 pin 2 end. And I removed R24 and replaced with a short. (see attached pic) This has made it better, but I am still noticing the R output as more noisy. The broadband nose is better, but there is also a more defined noise. kinda like bandpass noise I guess. So.... has anyone got a clue why this is? Why is the output noisy in the first place? Maybe I shoulda left R33 and R34 in place? But I don't see anything in the schematics that would suggest the output from the individual SSM chips is any different on the L and R sides of the bus, so I don't think the circuit needs to be any different for a true stereo output. Any help appreciated! Thanks! [Non-text portions of this message have been removed]
