HiYou need to boot the Emax
With the plus OS using a
Floppy with Plus OS
On it. After that you
Can see the external SCSI
Zip etc
Do you have a Plus OS
Floppy Disk? If not
You will have to download
The image from Esynthesist
EMXP site
Then use EMXP to burn a copy to floppy then boot your Emax with that floppy. Once the Emax is running off the Plus OS
Ayou will be able Load and save
To external SCSI ZIP.
If you haven't a way to burn the floppies
Contact me. For a small fee (around $5.00 US) plus the cost of S&H I will Make plus OS floppies for other users who don't have a floppy drive fitted XP computer system running OmniFlop (configuration needed to make the Emax OS floppies)
Greg
Le Sociere Des Oscillateurs Mystere
