Hi
You got to be carefull with potential latency problem; I don t know the size
of your internal drive, but have you thought about making a partition and
keeping it ³inside the box² ? If your drive is not big enough, seriously
think about replacing it with another one instead of getting external. I m
not saying FW is not good, but since size and power consomption seems to be
of an importance for you, can t beat internal drive for speed and space ! If
you do go external, lacie is always very reliable and lately, they came up
with firmware upgrade improving both FW 400 and 800.
Louis
> Can anyone recommend an external firewire drive for my Powerbook G4 800mhz?
> The idea is to transfer my desktop's EXS24 library - around 30 to 40 GBs. The
> drive
> would be used almost exclusively for the EXS library, although maybe called
> into
> action for audio recording if the internal can't handle it.
> Will the Lacie pocket drives work okay for this? Small size is important.
> Bus-powered
> would also be nice. What about those Porsche-designed versions?
> Thanks,
> Andy
