Korg Poly800/EX800 Users group photo
Poly 800 mk2 MIDI implementation
2008-10-30 by Michael Hawkins
Hi all,
I am not certain that the MK2 MIDI sysex patch format is the same as the EX.
I suspect it is different because the parameters are numbered differently and there are the additional effects parameters in the MK2 as well.
So if anyone has the MK2 service manual it would be great to get the MIDI implementation documentation into our files section.
Mike
To: korgpolyex@yahoogroups.com
Sent: Thursday, October 30, 2008 3:59:43 AM
Subject: [korgpolyex] Re: new to the world of poly 800 mk2
Hmm actually I was loading a EX-800 factory bank-lights flashed, midi
ox progress bar went fine. Pretty much assumed all went well. Went to
send a small bank of some user patches for the EX and nothing seems
to change.
So I *may* have been 100 percent wrong to assume...
the data dump for the EX is F0 42 21 01 10 F7
(see http://www.geocitie s.com/sunsetstri p/studio/ 3507/ex800info2. html)
----- In korgpolyex@yahoogro ups.com, "Frequency Spectrum"
wrote:
> Thanks ill let you know how i go.
> Im gona buy the bits for the slayer mod. you can get them from digi
key or
> farnell for pennies.
> well worth doing
> good luck
> On Wed, Oct 29, 2008 at 7:37 PM, april exe wrote:
> > Yep, infact you likely only have to set it up for output to the
Korg, I
> > dont think the Korg talks back to Midi ox although Im sure it
will. Ive
> > hardly gotten into it the manual . Still setting up a Mirage-
which is a bit
> > of a challenge to say the least. Today Ill go by our town freebox
to see if
> > I can find something with knobs to do the Korg filter mod :)
> > I dont recall them all but there *are* some settings in midi ox
that have
> > to be applied and it took some trial and error the first time I
used it with
> > an Emu Orbit- I think "pass sysex" is the most important one but
there are
> > some buffer settings in there as well.
> > Im off work the next 3 days, Ill try and get some patches up. Im
hoping to
> > "emulate" some polysix sounds as best as the EX will do at least.
I can hear
> > it a "little" bit in the presets...a "little" --well see-
> > Have fun:)
> > april.exe
> > email april.exe@.. .
> > <http://hotmail. com/>website http://april. exe.tripod. com
> > myspace www.myspace. com/aprilexe
> > To: korgpolyex@yahoogro ups.com
> > From: freqspec@...
> > Date: Wed, 29 Oct 2008 17:25:04 +0000
> > Subject: Re: [korgpolyex] Re: new to the world of poly 800 mk2
> > so you just plugged in midi cables and dumped the sysex from
midi ox?
> > On Wed, Oct 29, 2008 at 3:27 PM, icr2fan wrote:
> > Hi, My EX-800 Came yesterday and I had no trouble with MIDI-Ox,
my usb
> > interface and factory sysex.
> > No special settings were needed. Seemed to load right up.
> > 01-windows MIDI default is the M Audio UNO interface but when
using my
> > Korg TR driver as default and using the UNO w my Ensoniq SQ80
theres no
> > trouble. Think the MIDI-Ox setting is what counts here.
> > 02- In MIDI-Ox UNO is set for in and out with my controller added
to
> > the in as well
> > 03- will depend on what app your using but in MIDI-Ox you load the
> > sysex file and hir send.
> > As far as Ive seen the EX and Poly800MKII should be the same in
this
> > regard. Good luck. Seems like a pretty good OSC/Filt combo in
there.
> > --- In korgpolyex@yahoogro ups.com, "mark" wrote:
> > > i have the sysex original midi patch for my poly 800mk2, a
computer
> > and
> > > midi data send software. Can anyone tell me step by step what i
need
> > to
> > > do so that the korg goes into receive mode so i can send the
data to
> > it.
> > > Thanks
> > > Newbie Mark
> > You live life beyond your PC. So now Windows goes beyond your PC.
See how<http://clk.atdmt. com/MRT/go/ 115298556/ direct/01/>
