Korg Poly800/EX800 Users group photo
Mods complete (for now, anyway)
2012-11-23 by AARON
After thinking about it for a long time, I finally did it.  Or "them," to be more accurate.  Within the last couple of weeks, I've done mods to two of my Poly-800s: the Moog Slayer, 12/24 dB, FM-800, and battery backup on one machine, and just the Moog Slayer on the other.
Obviously, these mods really open up the sound-making capabilities of these machines.  At first, I didn't understand what the FM-800 was capable of until I did some reading.  Then, once I figured it out, I was blown away with what it can do, and really glad I did it.
The only other thing I'm thinking about doing is putting a knob on the front panel to control the noise level (parameter 33).  Has anyone done it?
Aaron
RE: [korgpolyex] Mods complete (for now, anyway)
2012-11-23 by backshall1
The filter FM needs a lot of harmonics to work with, so playing an interval
like a fifth really works well. You can do that with the chord memory, or in
double mode you can set the DC0 2 interval (parm 31). I don't think the
internal sequencer works when you are using chord memory so if you need the
sequencer you will have to use a double mode patch to get the interval. Set
the cutoff way down low, the resonance way up, and add a touch of FM.
I have also been thinking of adding a noise level knob, mostly because if
interactions with the external input I added. There seem to be three choices
when it comes to where to inject the external input signal into the VCA/VCF
(DCO1, DCO2, Noise). I currently have it connected to the DCO1 input but was
thinking of moving it to the noise input. In that case, I believe parm 33
would need to be up high to let the external sound through but then I would
get noise too, so a separate knob for noise level would be essential. I
would be very interested in hearing from people who added an external input
to see how they did it. There are definitely tradeoffs among the choices.
As for adding the noise knob, it might be as simple as replacing VR3 with a
full size potentiometer. It would take some testing to determine the exact
value to use, and R34, R35 might need to be changed so you can get the
minimum noise level down closer to zero. The current value of VR3 (1 Meg)
will take the noise level well above the factory spec of 0.3V p-p, so you
have to be careful there. It might be easier to put the pot from IC2 pin2 to
ground. Like I said, this needs some testing unless someone else has already
done it.
Don Backshall
  _____
From: korgpolyex@yahoogroups.com [mailto:korgpolyex@yahoogroups.com] On
Behalf Of AARON
Sent: Friday, November 23, 2012 1:48 AM
To: korgpolyex@yahoogroups.com
Subject: [korgpolyex] Mods complete (for now, anyway)
Aaron
Re: Mods complete (for now, anyway)
2012-11-23 by AARON
Hi Don,
I found a blog post in which a guy added a noise knob to his EX800. He doesn't say how well it works or anything. But he apparently just replaced VR3 with a full-sized pot. Not sure what value he used, though. Click here to see pictures of the mod.
Aaron
> done it.
> Don Backshall
> _____
> Behalf Of AARON
> Aaron
2012-11-23 by bimmerfan222
I just recently posted a vid on how I ran a external input to the filter on here.
http://launch.groups.yahoo.com/group/korgpolyex/message/5240
It's a crappy quality vid, but it gets the point across and demo's several different audio signals ran thru the filter along with ext. audio and the DCO's turned on too.
Here's a good pic of the Korg's NJM2069 filter for reference below-
http://img.photobucket.com/albums/v207/abcSweep/KorgNJM2069.jpg
I ended up using Pin 19 on the NJM2069 filter to inject an external audio signal.  Pin 1 is where I hooked up my ext. audio's ground.
What I discovered was this:
Noise goes into the filter at Pin 7.  Pin 8&9 are VCA control lines for the Noise signal.  Pin 10 is hard lined to Pin 19.
When I tried to inject the audio signal at Pin 7, I had to turn VR3 up to get the ext. audio signal thru.  You'd think I wouldnt have to do this, but that's exactly the reaction I got.. it was as if VR3 was controlling the VCA inside the filter.
I had the Noise parameter 33 set to max, thinking I could turn the Noise down with VR3 and Parameter 33 would control the VCA inside the filter chip.  But this isnt how it worked out.
What ended up happening was I had to turn VR3 back up in order to hear my ext. audio.  It was the only way I could hear my ext. audio signal when injecting it at Pin7.
So I decided to go to the next Pin in the Noise signal path to try and get my ext. signal into the filter.  I chose Pin 19.  When I did that, I ended up having to turn my ext. audio signal way down... but I was able to keep my Noise signal off and clearly hear my ext. audio.
I was able to keep DCO1/2 off completely using their Volume Parameters.  I could also turn DCO1/2 on with their Volume Parameters.. thus making it possible to have all four signals running thru the filter at one time-  DCO1, DCO2, Noise and Ext. Audio.
When I get back in there to do a permanent ext. audio jack, I'll most likely put some kind of volume attenuator either outside the case via a VR or a fixed value resistor inside the case.. I'm thinking fixed value or an internal VR will be the way to go.. to avoid an over-driven signal from getting thru (an ext. VR might get turned up too high accidentally).
The korg was very sensitive to the ext. audio volume.  I barely had my JX1 volume up.. I was using the Left/Mono output from the JX1, NOT the headphone output.
I dont know if an over-driven external signal going into the filter would damage it or not.. I was lucky it didnt happen to me.  But I will be very careful next time I go mucking around in there.
So my caution to anyone injecting a signal at Pin 19 is, start with a very low volume signal and barely bring it up.
I need to get back in there and re-check if I can turn Noise up/down independently of my ext. audio signal.  I cant think why on earth I couldnt.  But just for the sake of verification I'll do it using both the Parameter 33 Noise Volume control and the VR3 adjustment.
-Blaine
