Question about the FM Mod
2012-12-31 by eric justin
I just finished up modding my Poly 800 MKI and noticed something about the FM mod. It seems that with some patches, the mod only effects certain keys while it effects all keys in other patches. Why is this happening? Thanks Eric
2012-12-31 by bimmerfan222
Just a WAG.. but have you checked the difference in the Keyboard Track parameter settings between the patches that work and ones that dont seem to work correctly? My guess is the FM works best on patches with Keyboard Track set to "Full". --- In korgpolyex@yahoogroups.com, "eric justin" <djericjustin@...> wrote:
> > I just finished up modding my Poly 800 MKI and noticed something about the FM mod. It seems that with some patches, the mod only effects certain keys while it effects all keys in other patches. Why is this happening? > Thanks > > Eric >
I think i figured it out. The mod seems to only effect certain notes if in single mode or in double mode with dco 2 turned down low. Weird! --- In korgpolyex@yahoogroups.com, "bimmerfan222" <bperkins211@...> wrote:
> > Just a WAG.. but have you checked the difference in the Keyboard Track parameter settings between the patches that work and ones that dont seem to work correctly? > > My guess is the FM works best on patches with Keyboard Track set to "Full". > > --- In korgpolyex@yahoogroups.com, "eric justin" <djericjustin@> wrote: > > > > I just finished up modding my Poly 800 MKI and noticed something about the FM mod. It seems that with some patches, the mod only effects certain keys while it effects all keys in other patches. Why is this happening? > > Thanks > > > > Eric > > >
2013-01-01 by narfman96
This is the nature of FM. Some notes will produce odd dissonant frequencies and others will produce even harmonics. --- In korgpolyex@yahoogroups.com, "eric justin" <djericjustin@...> wrote:
> > I think i figured it out. The mod seems to only effect certain notes if in single mode or in double mode with dco 2 turned down low. Weird! > > > --- In korgpolyex@yahoogroups.com, "bimmerfan222" <bperkins211@> wrote: > > > > Just a WAG.. but have you checked the difference in the Keyboard Track parameter settings between the patches that work and ones that dont seem to work correctly? > > > > My guess is the FM works best on patches with Keyboard Track set to "Full". > > > > --- In korgpolyex@yahoogroups.com, "eric justin" <djericjustin@> wrote: > > > > > > I just finished up modding my Poly 800 MKI and noticed something about the FM mod. It seems that with some patches, the mod only effects certain keys while it effects all keys in other patches. Why is this happening? > > > Thanks > > > > > > Eric > > > > > >
2013-01-02 by Michael Hawkins
2013-01-02 by eric justin
Thanks mike That answers my question. --- In korgpolyex@yahoogroups.com, Michael Hawkins <korgpolyex800@...> wrote:
> > If you install the HAWK and AtomaHawk mod kits then the FM mod works consistently for both single and double mode. If you do the standard FM mod then you need to use double mode most of the time. In single mode you get four out of eight notes sounding with the FM and the other four not. And due to the way the Poly assigns notes to TG's, you don't get any way of deciding which TG's will or won't be FM'd. > > The HAWK/AtomaHawk fixes all that. > > > Mike > > > > ________________________________ > From: eric justin <djericjustin@...> > To: korgpolyex@yahoogroups.com > Sent: Monday, December 31, 2012 4:03 PM > Subject: [korgpolyex] Re: Question about the FM Mod > > > Â > I think i figured it out. The mod seems to only effect certain notes if in single mode or in double mode with dco 2 turned down low. Weird! > > --- In korgpolyex@yahoogroups.com, "bimmerfan222" <bperkins211@> wrote: > > > > Just a WAG.. but have you checked the difference in the Keyboard Track parameter settings between the patches that work and ones that dont seem to work correctly? > > > > My guess is the FM works best on patches with Keyboard Track set to "Full". > > > > --- In korgpolyex@yahoogroups.com, "eric justin" <djericjustin@> wrote: > > > > > > I just finished up modding my Poly 800 MKI and noticed something about the FM mod. It seems that with some patches, the mod only effects certain keys while it effects all keys in other patches. Why is this happening? > > > Thanks > > > > > > Eric > > > > > >
2013-01-11 by Robert Wells
