Korg Poly800/EX800 Users group photo
Poly 800 mk1 with no internal battery terminals
2013-04-15 by eric justin
Hey gang
 I was just about to start on my 5th poly 800 mod when I noticed something that I haven't run into before. This poly doesn't have terminals to soldier a lithium battery to. Is this a very early model with a different motherboard?
Re: [korgpolyex] Poly 800 mk1 with no internal battery terminals
2013-04-16 by Michael Hawkins
Yes, the early versions of the Poly-800 main board did not have a location for the lithium backup battery.
And instructions for installing your own can be found in the Poly-800 Servicing file section here:
http://f1.grp.yahoofs.com/v1/tFBtUSDu9aj3ccnxlZvE0mv7Zq6B08_Rsz514mGGfhYQ9yfYwvViPX_XY1T4-7YDiC_ycII1AXITVdEynUHq/1%29%20Poly-800/Servicing/poly8batt.txt
Mike
To: korgpolyex@yahoogroups.com
Sent: Monday, April 15, 2013 2:43 PM
Subject: [korgpolyex] Poly 800 mk1 with no internal battery terminals
Hey gang
Re: Poly 800 mk1 with no internal battery terminals
2013-04-18 by eric justin
Thanks Mike!
--- In korgpolyex@yahoogroups.com, Michael Hawkins <korgpolyex800@...> wrote:
> Mike
>  From: eric justin <djericjustin@...>
> Â
> Hey gang
2014-10-22 by <backshall1@...>
I don’t know if it is possible to direct link to the file. You may have to log into your Yahoo account, go to the korgpolyex group and click on the links for Files –> Poly-800 –> Servicing –> poly8batt.txt. Then it will ask you if you want to open or save this file.
This link will probably get you to the folder where the file is:
https://groups.yahoo.com/neo/groups/korgpolyex/files/1%29%20Poly-800/Servicing/
Don B.
Sent: Wednesday, October 22, 2014 10:38 AM
Subject: Re: [korgpolyex] Poly 800 mk1 with no internal battery terminals
Hi all :)
this is just what i needed but it looks like the link inst working ?
any help would be greatly appreciated
many thanks
2014-10-23 by bperkins211@...
you should do a data dial while in there too.
this rotary switch (NOT AN ENCODER)
http://www.mouser.com/Search/ProductDetail.aspx?R=SRBM1L1400virtualkey68800000virtualkey688-SRBM1L1400
can be placed in parallel with the +/- value switches.
turn the knob cw and value goes up,
turn it ccw and value goes down
easy, just find your select line for those switches, place it on one side of each switch, then other side to the proper cath side of the diodes linked to the data bus.
no extra logic or circuit needed
it's not a cheap switch, but even at $15 shipped it is a fair price for a cool mod that's easy to install.
you can't change the numbers too fast though, skinny knobs can be turned too fast, having a fat knob will help slow down the turning.. guess that's why early encoder data dials were fat too.. to make you slow down.
see it on my HAWK
Data Dial Demo
~Blaine
