Re: [L-OT] Good way to get a cheap 6-string bass guitar?
2001-11-10 by texture444@aol.com
kool, don't know how much help thisall will be, but: the danelectro baritones are cheaper than 400-600 USD; i think they're pretty cool. you can use a heavier gauge string than is 'standard', raise the action of the instrument slightly, and then de-tune the instrument more deeply into the bass-range; i don't know how far ye can go, though. (i have an old hofner 6-string bass, and a veillette/tokai-strat baritone 'bastard'). best, dt / s-c
>I do remember reading or hearing once, that a good way to go to get your > >hands on a reasonably affordable 6-string bass was to get a baritone guitar > >(fretted or unfretted as per choice) and then string it with some specially > >made D'Addarios. If I remember, the type particularly mentioned was the > >XL155. I could be wrong on the model number because I didn't write it down > >straight away although I meant to. > >Do any of you out there have any experience of doing something like this? > >Seems like it could be a good way to go because from what I've seen one >can >get perfectly reasonable (fretted) baritones starting at around the >$400-$600 mark (please don't laugh at me!!!). But ... I really wouldn't > >want to do this, with my present relative lack of funds, if it turned out > >that the sounds and possibilities were not quite what I wanted and that >in >the long run it had been a waste of time and money. > >I'm quite prepared to go down to my local music shop to see if they'd get > >some of those strings in, then pick up a baritone, and plead with them >to >string one up and let me play around with it for a while ... but what with > >the vast experience that I'm sure is present amongst you lot, I kind of > >figured that this would be as good a good place as any to start. > >Any of you got any thoughts on this? Or done anything like it? >Do those D'Addarios do the job they're supposed to, or is there some other > >set of strings that anyone would recommend. You get the picture. > >Any input would be very greatly appreciated. My thanks is all you'll get, > >actually, but I hope it'll be enough. (Well ... that and a mention in the > >credits of the hit album that I'll create once I get such an instrument!!)
