The Logic Off Topic list
Re: [L-OT] RE: GEN LOG SET UP MY EUROACK
2002-05-26 by David Eager
DbbBrook@... wrote:
> I was just given a BEHRINGER eurorack with 6 channels (MX 602) I
> understand
> right. I plug a mini jack in the back of g4 and then plug into line 1
> on the
> mixer.  Main out is where I plug the amp in.. When I play a track
> already
> made in logic it sounds very fussy and quiet.
Channel 1 in the MX602 is a mono channel. You need a special cable to
plug in the Mac. [called a Y-cable or insert cable] One end should have
a stero plug, and there be 2 mono plugs on the other end. You may only
be able to get one with a 1/4" stereo plug, in this case you will also
need a 1/4"-to-mini stereo adapter.
 Then you plug the stereo end into the Mac and the mono ends into either
3/4, 5/6 or Tape-In [which takes different kind of plugs called RCA
plugs]. In fact you may find it easiest to get your hands on a
'mini-stereo to RCA' type lead.
Hope this helps :)
Dave Eager
