The Logic Off Topic list
Re: [L-OT] switching between softsynths with evolution mk225
2003-01-24 by RayMaxer
> Hi. I use many different softsynths, all of which have different CCs for
> different parameters on the softsynths. I'd love to set up "maps" for each
> softsynth so that I can instantly recall the setup for each softsynth. Is
there
> a way to do this with the MC225?
> i.e. Synth one uses #75-82 for the parameters I want; Synth 2 uses #85-92
for
> the parameters I want. Is there a way I can instantly recall Settings for
Synth
> 1, then for synth 2, so that I don't have to remap the CC #s each time I
switch
> synths? Thanks much, Robert
It depends on if the Evolution has the presets for controler routings..
Or you could do it via Environment Transformers and cable the block of
them... if you need to control another synth cable another block of
transformers...  (the trasnformers which route control 75 to 85, 76 to 86...
etc).
Ray.
Digital Illusions.
