Advice needed on Mixer Servicing or contact cleaning
2003-10-13 by Paul Crowley
Although I'm increasingly doing mixing inside of Logic, I still use an old Mackie 1604 quite heavily. I frequently get crackles and dropouts when using the Bus Inserts (which are basically, stereo jacks). I'm guessing that the contacts need a good clean - the cables have been replaced several times, they're never moved about, yet the problem always returns. Another giveaway - turning up the gain tends to stop the dropouts (which would suggest to me poor conduction). So - can anybody suggest a good way of cleaning these contacts, or do I need to get the unit serviced? A friend once told me of a jack shaped object (mildly abrasive) that you inserted into the socket to clean the contacts. I've not been able to find such a thing, but would apprecioate any input from soemone who can recommend a way of improving/cleaning the contacts in my setup in any way. Any advice much appreciated
