The Logic Off Topic list
Does iTunes do PQ-coding?
2004-03-09 by remcomuntz
In MacOS 9 I made my mastered CD's with Toast/Jam. Now, in MacOS X 10.3 I only use
iTunes. I wonder if it's a proper CD when you burn it with iTunes. Is it compliant (with PQ-
coding), so it can be used as a master, so it can be duplicated by a duplication company.
Remco
Re: [L-OT] Does iTunes do PQ-coding?
2004-03-11 by Brian Pylant
> 10.3 I only use
While I do not know for certain, I doubt it - I don't think iTunes was
ever intended for that purpose, so it's likely that they never
incorporated those functions.
Jam is available for OS X... oh how I wish Sound Forge/CD Architect
were available for OS X...
Brian
___________________________
Logic Audio Platinum 6.3.3
PowerMac G4 933MHz
OS X 10.3.2
1 GB RAM
M-Audio Delta 24/96
   (fed via S/PDIF from a
    Yamaha DSP Factory)
Re: Does iTunes do PQ-coding?
2004-03-11 by Remco Muntz
>> 10.3 I only use
Well, I don't mean I have to be able to edit the coding. The question
is because I'm about to finish a CD with about 6 songs and ofcourse
there's no problem to make a CD out of it with iTunes. I just place the
songs in a playlist and burn it. But from that CD I want a CD-factory
to make 100 duplicates (they burn it, because it's quite a small
number). I think it will work fine, but just wanted to be 100% sure.
Remco
Re: [L-OT] Re: Does iTunes do PQ-coding?
P & Q codes are completely irrelevant if they are burning CD-Rs. You only
need to worry about supplying a PMCD (with P & Q codes) for replication.
Brian
2004-03-12 by Remco Muntz
> only
> replication.
Thanks, that's what I needed to know.
Remco
