DC Offset
2004-10-17 by mandcmiller
Hi Y'all, It seem that I am having DC offset problems when I trim short audio files, such as drum hits. This does not seem to be a problem with longer files. Anyone out there with any similar experiences? How do you remedy the problem? I've been using the remove DC offset in the sample editor for the shorter drum samples, but I like to run mixes through the Ren EQ with a steep cut @ 20Hz to prevent DC offset to appear on bounces. Are there any filter out ther that work around 10Hz? Thanks, Matt www.millertone.com
