Re: [LUG] Pitch Correction vs Autotune
2005-04-15 by HKC
I have moved this to the OT group because I find this has very little to do with Logic CWB wrote: Unless a production requires varying tempo or the > drummer is speeding up or slowing down. Which is exactly what I meant, if you have a break and start by ear (no click) you will almost always naturally start a different place than the machine. I have done quite a bit of copying live drums to midi and I have often been surprised with the tightness (BPM wise) of these old recordings. Something like Here Comes The Sun by the Beatles is as tight as a beatbox until the mid 8, the sun sun sun part, at which point he changes the tempo slightly. That slight very musical change would not have been these days because of the convenience of the clicktrack. Older stuff from the thirties and fourties are often completely without a on-going beat which I find interesting. Just because everything is kept completely in time these days doesn't neccesarily mean that it's the only way. Listen to Somewhere Over the Rainbow by Judy Garland, there's dynamic tempo for you. The tempo alters with the mood of the songline and not the other way around, actually something that would more or less require everthing to be recorded at the same time. My guess is that those skills have disappeared because it's quite difficult, requires very good musicianship and, well let's face it,it's hard to dance to but who wants to dance all the time. The same thing with the autotune, if tuning and intonation becomes too much of an issue you might end up having to autotune everything but the sounds out of machines which in my opinion would be a shame.
