The Logic Off Topic list
Corrupt Tracks
Corrupt Tracks
2005-08-17 by Josh
I recorded a long practice session last night with my bands. 12
tracks at 24 bit/44.1 Khz. Got home and opened the song off of the
portable FW HD on my desktop and it gave me errors like "what kind
of file is this", "8 bit files cannot be used", etc...
The file is the exact same size as all the other files that were
recorded.
I researched and found out about using audacity to import the raw
audio data to be later exported to whatever format, but no matter
what input paramaters I chose (16/24/32 bit PCM/float/dwvw
big/little/no-endian) the imported audio was unusable. Extreme
static and distortion, and the little audio you can hear in the
background is sped up it seems.
Why is this happening? How can I recover my track? Is there some
other software/platform besides logic/osx that would be more
reliable? I'm sick of random crashes and corruption which IMO is a
hallmark of working with Apple software. My PC rarely ever crashes.
Setup:
I use Logic 6.4.3 and OS 10.3.9 on 2 different machines. One is a
PB400 the other is a G4 DP1.25. Both have a gig of ram. I also use
the Waves V4 diamond plugins extensively. I have a MOTU 828 and run a
digimax LT into it's optical in. Mostly I just record bands... around
12 tracks simultaneously at 24 bit. I use a LaCie firewire HD with my
PB to do this on location (the built in HD is too sensitive to
vibration). I then load the song up at home on my DP1.25Ghz G4 for
mixing and overdubs.
Josh Brown
Undertone Records
Seattle, WA
Re: [L-OT] Corrupt Tracks
2005-08-18 by Mychal
>recorded.
reliable?
Invest in LOgic Pro 7
