The Logic Off Topic list
Trying to find some simple MIDI switches to buy.
2006-01-22 by Roman Pirie
I need three MIDI switches that have one in and two outs with a switch
that can choose the destination of either output. So if I had a master
keyboard outputting into the MIDI switch in then I could switch between
the two outputs.
My searching on the net found Phil Rees and Kenton MIDI switches. They
are both discontinued products. This makes me think the need for MIDI
switches has changed over the years.
I need three of them.
Roman Pirie.
Re: Trying to find some simple MIDI switches to buy.
2006-01-22 by Pete Thomas
> the two outputs.
As you are posting to the Logic EXS forum, I'm assuming you need this to
split your master keyboard to more than one EXS instrument at a time.
You don't need a MIDI switcher to do this, it can be done within the
Logic environment. You would jsut change the channel on your keyboard.
e.g the Channel splitter. More info at:
http://www.petethomas.co.uk/logic-environment-downloads.html
Hope this helps
Pete Thomas
- Free Logic Icons, Environments and EXS Instruments
