exit from debug state in THUMB mode
2005-11-04 by radoslaw_mitura
When I enter debug mode through jtag I made following: 01. read R0 (arm or thuumb instruction) 02. read PC (arm or thumb instruction) 03. If THUMB detected switch to arm (bx) 04. read r1 to r14 (arm instructions) 05. read cpsr and spsr (arm instructions) 06. modify read cpsr to get proper information about mode (arm/thumb bit) - only in host software. When I exit from debug state: 10. restore r1 to r15 (arm instruction - r15 is modified to reflect correct address after 12) 11. restore cpsr 12. restore r0 (arm or thumb instruction) I have a problem in step 11-13 when I have to restore cpsr. I don't make a jump at the end of restore. Do I have to restore cpsr with thumb mode depended on the state I entered the debug state? I don't know if the next instruction after cpsr resore should be also depended on the state I entered debug mode. Sometimes when I exit in thumb (I have entered in thumb) I got exception (undefined instruction), but not always. What will happen if the processor receive interrupt durring debug mode - should I exit in the state I entered debug mode or should I check interrupt flag before exit? Maybe I'm making something wrong - could someone describe how to do it properly?
