Lpc2000
Help With lpc2214 and GNU-ARM Comiler
2005-11-04 by Delbert Martin
I have the compiler and have it working for an lpc2106. I used the
lpc2106_gcc example and tried to modify the boot.s and the
lpc2106.rom-ld files to match the difference in ram locations. I'm not
sure what the problem is. Anyone have good boot.s/CRT and linker
scripts. Help?
I will provide source and binaries at request.
--Del
Re: [lpc2000] Help With lpc2214 and GNU-ARM Comiler
2005-11-04 by Tom Walsh
>scripts. Help?
Try running {arm-elf-}objdump -h -S <myfile>.elf  ??
That listing, which will be very large, shows you where the linker put
stuff.
TomW
>--Del
>Yahoo! Groups Links
2005-11-05 by Sten
> scripts. Help?
> --Del
This is easy. You must adapt the MEMORY section in your linker script
file. No need to make changes in boot.S. Can you attach your linker script?
Sten
 Do you need a tiny and efficient real time
 operating system (RTOS) with a preemtive
 multitasking for LPC2000 or AT91SAM7?
   http://nanortos.net-attack.de/
 Or some open-source tools and code for LPC2000?
   http://www.net-attack.de/
Re: Help With lpc2214 and GNU-ARM Comiler
2005-11-06 by Delbert Martin
Yup, I already did that, I thought I have already replaied, but I
found I was missing a Zero when Setting an IO Pin, so the code was
actually working I just didn't know it.
--Del
> > scripts. Help?
> > --Del
script?
> Sten
