Lpc2000
unsigned long versus unsigned int on ARM7
2005-11-09 by rtstofer
I have noticed that many folks are using 'unsigned long' for 32 bit
entities and I got to wondering if I am doing things wrong (again!)
Looking at limits.h I come up with:
unsigned char -> 8 bits
unsigned short int -> 16 bits
unsigned int -> 32 bits
unsigned long -> 32 bits or 64 bits depending on architecture
Assuming that I care that my code is portable, what is the
considered opinion on unsigned int versus unsigned long for 32 bit
entities?
I followed a thread on the Internet that stated that the latest
standard required that the rank of each type (where rank wasn't
clearly defined in the minds of the participants) had to be greater
than its predecessor, not greater than or equal to.  If that is
indeed the standard, the rank of unsigned long must be greater than
unsigned int and thus reserved for 64 bit kinds of things.
Now, I realize my stuff is never going to move to a SPARC but it
would be nice to get it right.
I have been trying to avoid the use of macros such as ULONG just to
be pedantic, I suppose.
So, what is everyone else doing?
Richard
RE: [lpc2000] unsigned long versus unsigned int on ARM7
2005-11-09 by Gromann, Klaus
The difference between long and int is machine dependend.
int depends from the processor type, that means int is 16 bit on a 16
bit machine and 32 bit on a 32 bit machine.
long is at least 32 bit.
short is allways 16 bit.
The best way to write portable code is to define your own datatypes.
i.e. for a 32 bit architecture
#define u8 unsigned char
#define u16 unsigned short
#define u32 unsigned int
and so on.
If you change the architecture you only have to change the
"datatypes.h"-File.
regards
Klaus
From: lpc2000@yahoogroups.com [mailto:lpc2000@...m] On Behalf
Of rtstofer
Sent: Wednesday, November 09, 2005 5:03 PM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] unsigned long versus unsigned int on ARM7
entities?
Richard
Yahoo! Groups Links
Re: [lpc2000] unsigned long versus unsigned int on ARM7
2005-11-09 by Jim Parziale
That's why it's a good idea to define your types based on sizes:
S8 -> signed 8-bit
U8 -> unsigned 8-bit
S16 -> signed 16-bit
U16 -> unsigned 16-bit
etc.
This way you can define these in one place, base other types (structs, ...)
and objects off of these, and throughout your code you know what you're
getting.
> entities?
> Richard
Jim Parziale
Email: nuncio.bitis@...
Malden, MA
2005-11-09 by Richard
First of all, re: standards, the old C86/C89/ISO90 Standard will go on for
a quite a while. Most (embedded) compilers have not moved to fully support
C99 and do not appear to have too much pull to do so. I am not aware of
this "latest standard" you mention but I have not tracked comp.std.c or
some such for a while.
Second, if you want to be portable and care about the actual # of bits, you
should always use your own typdefs such as
uint32, uint64 etc. anyway.
>entities?
// richard (This email is for mailing lists. To reach me directly, please
use richard at imagecraft.com)
Re: unsigned long versus unsigned int on ARM7
go on for
support
aware of
comp.std.c or
I believe the discussion was related to C99 as it appeared to change
the definition from previous versions (or it did in the minds of the
participants).  But, I hate to mention things like 'standards'
because I haven't read them and I wouldn't understand them if I did.
bits, you
OK, I give in.  It is no effort to create a 'datatypes.h' and this
is the approach I have used before.  There is certainly good reason
to get this squared away early.
Thanks to all!
Richard
2005-11-09 by Paul Curtis
> entities?
No difference on many 32-bit compilers.
That is wrong.  The C standard requires that the following equality and
inequalities hold:
1 = sizeof(char)
sizeof(char) <= sizeof(short) <= sizeof(int) <= sizeof(long) <=
sizeof(long long)
It is quite possible to produce a standard-conforming compiler where all
types are 64 bits in size.  In fact, the Texas Instruments 320C40
compiler had a 32-bit char, short, int, and long.  Yes, it was not a
byte-oriented machine and much trouble with byte-oriented protocols
ensued.
Try investigating <stdint.h> if your compiler has it.
-- Paul.
Klaus,
Actually, it is compiler defined.
int is supposed to mirror the natural word width of the machine, yes.
Correct.
No, short is required to cover the closed interval [-32768, 32767].
That does not infer 16 bitness for short--short *can* be modeled with a
32-bit type (cf 320C40 compiler cited in a previous message).
Or try <stdint.h> and use uint_8 and so on...
-- Paul.
Re: [lpc2000] Re: unsigned long versus unsigned int on ARM7
2005-11-09 by David Hawkins
> bits, you
> Thanks to all!
I use <stdint.h> to get the C99 types; int32_t, uint32_t, etc.
If the compiler doesn't have a stdint.h, then write one.
There are already too many versions of code with s32, S32, INT32, ...
definitions out there, I figure go with the C99 names, even
if your compiler is not C99 compliant.
Dave
2005-11-09 by Ake Hedman, eurosource
> Dave
This is a *very* good suggestion. During the years I have used many
different constructs but as you write it is probably time now to go for
the C99 types once for all. Is there a place where they all are listed?
I have never come across a stdint.h file yet.... ;-)
Cheers
/Ake
Ake Hedman (YAP - Yet Another Programmer)
eurosource, Brattbergavägen 17, 820 50 LOS, Sweden
Phone: (46) 657 413430 Cellular: (46) 73 84 84 102
Company home: http://www.eurosource.se
Kryddor/Te/Kaffe: http://www.brattberg.com
Personal homepage: http://www.eurosource.se/akhe
Automated home: http://www.vscp.org
>>Dave
> Cheers
> /Ake
On my Cygwin install
$ find . -name stdint.h -print
./usr/include/mingw/stdint.h
./usr/include/stdint.h
there's a couple. Do the same on your install.
Dave
2005-11-09 by seangra
From a standards point of view the only thing that can be guaranteed
for the normal basic ordinal types is this:
In section 6.1.2.5 the Standard states, "There are four signed
integer types, designated as signed char, short int, int, and long
int." ... "In the list of signed integer types above, the range of
values of each type is a subrange of the values of the next type in
the list."
In other words,
The standards make no guarantee of how big any of those actually is,
only that the sizes adhere to that.  Technically all basic ordinal
types can be the same size, depending on the native type of the
processor.  It's only by convention that most compilers limit char
to 8-bit, short to 16-bit, and "int" is fairly universally used
as "machine-type word in length".  The alignment is also left up to
the discretion of the compiler.  It may declare a char to be 8-bit,
but always align it on 32-bit boundaries, meaning that it could
actually be used as a 32-bit number (in some cases).  printf is a
bad example of this.  I see people all over the place always use %i
to display a number.  Again, works great on 32-bit with 32-bit
alignment, but when ported to a different platform things start to
screw up.
Although it's a great idea to use C99 for "standard" size-defined
ordinals when you need them, keep in mind that they should only be
used when you must be sure of the size of your variable.
If you decide to write everything with uint32_t or uint16_t, keep in
mind that it will not execute as efficiently on machines that are
not native to that type.  I.e. if you want to use a loop counter,
then just use an int or unsigned int, which "almost" guarantees that
the compiler will choose the most efficient type for the machine.
I've seen code where people insist on using uint32_t everywhere,
which works great on 32-bit machines, but when compiled for our
lovely 8051s the code runs like a total hog (not to mention using a
lot more memory that necessary).  That's why I usually have 2 sets
of defines, one for specific variable lengths, one for "minimum
lengths".  For example, like this:
#ifdef __8051__
#define uint8  unsigned char
#define uint16 unsigned short
#define uint32 unsigned long
#define mint8  unsigned char
#define mint16 unsigned int
#define mint32 unsigned long
#elif defined (__ARM7__)
#define mint8  unsigned int
#deifne mint32 unsigned int
#elif ...
(etc)
In other words
#define mint8  <at least  8-bit in length>
#define mint16 <at least 16-bit in length>
#define mint32 <at least 32-bit in length>
#define uint8  <exactly  8-bits in length>
#define uint16 <exactly 16-bits in length>
#define uint32 <exactly 32-bits in length>
This way I can be guaranteed that if I need to use a machine-type-
efficient counter that only needs to go between 0 and 50 then I use
an mint8.  If I need a number that must be 32-bit, I use a uint32.
-- Sean
--- In lpc2000@yahoogroups.com, "Ake Hedman, eurosource" <akhe@b...>
INT32, ...
> > Dave
many
go for
listed?
> Cheers
> /Ake
> Dave
Yes I noticed them after I replied to your mail. Thanks!
Cheers
/Ake
2005-11-10 by rtstofer
equality and
> inequalities hold:
> 1 = sizeof(char)
> sizeof(long long)
As I understood the debate, the C99 spec has changed the inequality
to strictly <  not <= so there had to be a difference in size
between the various types.  But this may not be correct...
From the C99 standard section 6.3.1.1:
6.3.1.1 Boolean, characters, and integers
1 Every integer type has an integer conversion rank defined as
follows:
— No two signed integer types shall have the same rank, even if they
have the same representation.
— The rank of a signed integer type shall be greater than the rank
of any signed integer type with less precision.
— The rank of long long int shall be greater than the rank of long
int, which shall be greater than the rank of int, which shall be
greater than the rank of short int, which shall be greater than the
rank of signed char.
— The rank of any unsigned integer type shall equal the rank of the
corresponding signed integer type, if any.
But, I think the real answer is in section 7.18 where the standard
deals with <stdint.h> and defines macros that represent specific
widths.  I think I need to read this a little more carefully.
Then there is the matter of which standard applies; '99 or something
earlier.  Oh, and whether the compiler in question even claims
standard compliance.  Some don't...
Richard
2005-11-10 by Richard
>equality and
> > inequalities hold:
> > 1 = sizeof(char)
> > sizeof(long long)
Richard, I don't recall whether they use the same language for C86/C89/etc.
or not, but my reading of your excerpt is that your interpretation is
incorrect. Looks to me that under C99, it is still
sizeof(char) <= sizeof(short) <= sizeof(int) <= sizeof(long) <= sizeof(long
long)
>follows:
>Richard
>Yahoo! Groups Links
2005-11-10 by Clyde Stubbs
> follows:
> \ufffd No two signed integer types shall have the same rank, even if they
> \ufffd The rank of a signed integer type shall be greater than the rank
Read this carefully - what it says is that IF there are two types with
different precisions, then the one with less precision must have the
lower rank - it does NOT say that types with different rank must have
different precisions.
While the wording is different to that of C89, the meaning is the same.
Clyde
2005-11-11 by Bruce Paterson
> Texas Instruments 320C40 compiler had a 32-bit char, short,
> int, and long.  Yes, it was not a byte-oriented machine and
> much trouble with byte-oriented protocols ensued.
Or even less obvious the 24bit gnu based C compiler for the Motorola
series of DSP's (5600x), char, short, int and long were all 24 bits. To
make things work properly using the same code on a test PC we had to
ensure int-like variables were forced to be 32bits (rather than 16bits),
so it was lucky it could be all done in one file where my generic types
were defined.
A situation like this does mean you should allow for a type that is the
natural int of the machine as well as the specific types like int32_t.
In most cases you probably don't want a 32bit counter on the PC to be
forced into a double word 48bit on the DSP; for most purposes a 24bit
counter will do. I tend towards some global use types like "COUNTER" and
"INDEX" that I set appropriately in the global types file, as well as
min_no_of_bits types like INT32_T where you really do mean you need
32bits (or more).
Bruce
2005-11-11 by rtstofer
--- In lpc2000@yahoogroups.com, "Bruce Paterson"
Motorola
bits. To
to
16bits),
types
> were defined.
is the
int32_t.
be
24bit
like "COUNTER" and
as
> 32bits (or more).
> Cheers,
> Bruce
Yes, as I get further into stdint.h I think is will clear up.  And,
what about portability?  On these embedded things portability of the
hardware specific code is not going to happen anyway.
It's just that my experience has been limited to 8 bit micros for
far too long.
Richard
