Lpc2000
Timer Interrupt on Crossworks
2005-11-10 by mhaines4102
I have a dumb question. I am embarrassed to ask but... I am using a
timer interrupt. My setup is as follows:
	/* Timer 0 interrupt is an IRQ interrupt */
	VICIntSelect &= ~(0x10);
	/* Enable timer 0 interrupt */
	VICIntEnable = (0x10);
	/* Use slot 0 for timer 0 interrupt */
	VICVectCntl0 = 0x24;
	/* Set the address of ISR for slot 0 */
	VICVectAddr0 = (unsigned long)timer0ISR;
	/* Reset timer 0 */
	T0TCR = 0;
	/* Set the timer 0 prescale counter */
	T0PR = 2500;
	/* Set timer 0 match register */
	T0MR0 = 1000;
	/* Generate interrupt and reset counter on match */
	T0MCR = 3;
	/* Start timer 0 */
	T0TCR = 0x01;
	T0IR = 0xFF;
The interrupt was being called, then it stopped. I changed some
settings and it came back, then it stopped again. I added T0IR = 0xFF;
to the end of the setup and it worked, then it stopped again. What
have I missed? I am beginning to feel like a goof.
Mike Haines
Re: [lpc2000] Timer Interrupt on Crossworks
2005-11-10 by Karl Olsen
---- Original Message ----
To: <lpc2000@yahoogroups.com>
Sent: Thursday, November 10, 2005 9:40 PM
Subject: [lpc2000] Timer Interrupt on Crossworks
> /* Reset timer 0 */
> T0TCR = 0;
> T0PR = 2500;
> T0MR0 = 1000;
> T0MCR = 3;
> /* Start timer 0 */
> T0TCR = 0x01;
> T0IR = 0xFF;
Have you remembered a
   VICVectAddr = 0x00;  /* Clear interrupt flag in the VIC */
and a
   T0IR = 0x01  /* Clear the match 0 interrupt flag */
in your interrupt handler?
Karl Olsen
Re: Timer Interrupt on Crossworks
Well this is what I have now and it is working:
	/* Clear a selected interrupt. 0s should do nothing. */
	VICIntEnClr = 0x0000;
	/* Clear a previous interrupt call */
	VICVectAddr = 0x0;
	/* Reset timer 0 */
	T0TCR = 0;
	T0PR = 2500;
	T0MR0 = 1000;
	T0MCR = 3;
	/* Start timer 0 */
	T0TCR = 0x01;
	T0IR = 0xFF;
I just went through the book and made sure anything that could be
reset, was.
Mike Haines
> From: "mhaines4102" <mhaines4102@y...>
> > /* Reset timer 0 */
> > T0TCR = 0;
> > T0PR = 2500;
> > T0MR0 = 1000;
> > T0MCR = 3;
> > /* Start timer 0 */
> > T0TCR = 0x01;
> > T0IR = 0xFF;
> and a
> Karl Olsen
2005-11-10 by rtstofer
--- In lpc2000@yahoogroups.com, "mhaines4102" <mhaines4102@y...>
> 	/* Reset timer 0 */
> 	T0TCR = 0;
> 	T0PR = 2500;
> 	T0MR0 = 1000;
> 	T0MCR = 3;
> 	/* Start timer 0 */
> 	T0TCR = 0x01;
> 	T0IR = 0xFF;
0xFF;
> Thanks,
> Mike Haines
I have Timer0 interrupt 2000 times per second using a prescale of 2
and a count of 14400.  Besides toggling an LED, it increments a tick
counter for the uIP (TCP/IP) stack - specifically for telnet.
Here is my Timer0 setup (setup.c):
// set up Timer 0
TIMER0_TC    = 0; // clear the timer count
TIMER0_PR    = 1; // prescale divide by 2
TIMER0_MR0   = 14400; // divide by 14400 to get 2048 ints per second
TIMER0_MCR   = 0x03; // interrupt on match, reset on match
TIMER0_TCR   = 0x01; // start the timer
VICVectCntl3 = 0x00000024; // set priority 3 for Timer 0
VICVectAddr3 = (unsigned long) T0ISR; // pass the address of the ISR
VICIntEnable = 0x00000010; // enable interrupt
This is my interrupt routine (interrupt.c):
void T0ISR(void)
 ticks++;
 if ((ticks & 0x07FF) == 0) // every 2048 ticks
 if (ticks & 0x0800) // every 4096 ticks
 IOSET = LED_YELLOW;
 else
 IOCLR = LED_YELLOW;
 TIMER0_IR = 0x01;
 VICVectAddr = 0xFF;
Here is my interrupt routine prototype (interrupt.h):
void T0ISR (void)   __attribute__ ((interrupt));
The only other changes I have made is to increase all of the stacks
to 64 bytes from 4.  Not necessary perhaps, but safe.
Richard
