Philips: should pull AN10406 appnote?!!
2005-11-15 by Tom Walsh
Perhaps someone who is better versed in MMC SPI stuff should take a good
look at Philips AN10406. There appears to be some problems with the
example code it contains. Two issues jump right out in the file:
spi_sd.c...
In mmc_init(), look at the _second_ for() loop:
======== begin mmc_init() ==========
int mmc_init( void )
DWORD i;
/* Write data pattern for testing */
for(i=0;i<MMC_DATA_SIZE;i++) {
MMCWRData[i] = i;
SDStatus = 0;
#if !USE_CS
IOCLR0 = 0x00100000; /* clear SPI SSEL */
#endif
/* Initializes the card into SPI mode by sending 80 clocks */
for(i=0; i<10; i++) {
MMCCmd[i] = 0xFF;
SPI_Send( MMCCmd, 10 );
======== snip =================
The sizeof(MMCCmd) is only 8 bytes, not 10.
While that is not too bad, it gets more interesting as you read the
mmc_block_write(). During mmc_init(), CMD16 has set the blocksize to
0x200 (512 bytes), okay? But, when they write the data during
mmc_block_write(), they only write 8 bytes. Then they proceed to hold
the chipselect down and poll 255 times for a completion status code! Of
course, it dies, while the MMC gets deadlocked waiting for the rest of
the data...
Another issue is that the mmc_write_block() does not look at BUSY from
the MMC, but assumes a delay loop is an answer to when a write has
completed!!!
With my understanding of MMC and the reading of the code in AN10406, it
looks as if mmc_block_write() is never going to write a block to the
MMC? After compiling and debugging the code for a few hours, I'm
satisfied that there are problems with it (appnote code).
The night was not a total loss, working with the app note had made me go
back and take a critical look at the MMC spec + my code. Heh, my code
is working flawlessly now!
IMHO, I strongly urge Philips to remove AN10406 from their website until
a code review has been performed.
TomW
