Lpc2000
current limits for 1.8V
2005-11-17 by Gus
Is 50mA enough for the 1.8V on the LPC chips? The LPC2114 data sheet
says 30mA but what is the maximum? I remember somebody on this group
saying it was always more than 30mA.
Any comments? Thanks, Gus
Re: [lpc2000] current limits for 1.8V
2005-11-17 by Tom Walsh
Well, you do have surge currents while the device is "leaping" into
doing work..  In that case, usually a low ESR capacitor such as tantalum
or a good quality ceramic device located "near" the 1.8v supply will
handle surge currents.  Something between 0.1uf and 1uf is a good
value.  I have several 10uf tantalums (3) on my dual LPC2xxx board,
these are located at "busy" current nodes, also I have bypassed (cap
located close to the device across the supply line) all devices with
0.1uf caps.
Generally, you do the best guess, then look at the initial prototype
board with a scope to see if there are any hot-spots which need a local
current store / dump (capacitor).
TomW
>Yahoo! Groups Links
Re: current limits for 1.8V
2005-11-17 by philips_apps
Gus,
the tested limit is 70 mAs to be considered a fail.  Running at 60 MHz
from SRAM with all peripherals active and V18 towards the upper end
(1.95V) it is possible to exceed 50 mAs but we never measured anything
above 60 mAs.
Robert
