fredvermejo wrote:
>Hi! Everybody!
>I\ufffdm using GNUARM 4.0.1 and when I run my code step by step (using
>Insight, OCDRemote and a parallel wiggler), the steps showed at
>Insight window don\ufffdt follow a logical sequence, the mark jumps to
>lines (down and up) although the program works fine.
>There is something wrong with my parameters to generate the code???
>I already have used -O0 and -O2 and the result is the same.
>Somebody have experienced something like that?
Yes, but when I located _all_ the -O2 or -Os optimization compiler flags
and changed them to -O0, everything worked as expected. You have to
remember that the ARM code uses conditional execution instructions.
These opcodes conditionally will execute based on a condition flag
(Zero, Carry, no Carry, etc). While debugging this type of code, you
will have counter-intuitive behavior.
Try turning on a mixed source + assembly view in the debugger and take a
hard look at the underlying code.
TomW
>Thanks in advance.
>Fred
>Yahoo! Groups Links
