Lpc2000
LPC2148, 1.5k pull-up for USB D+
2005-11-18 by seangra
How important is the value 1.5k for the pull-up?  Would another value
work, like 2.2K?  I see in the spec it's quite serious about the 1.5k
value, but doesn't really seem to explain why (other than time to
pull-up).  Has anyone played with this?
I'm assuming the LPC2148 doesn't have internal pullup?
Re: [lpc2000] LPC2148, 1.5k pull-up for USB D+
2005-11-19 by Arie de Muynck
It's from the USB spec, based on maximum length cabling and required maximum
R-C time for enumeration. Don't play around with it, be sure and use 1K5.
Not likely, because the chip process variation is more than the required
accuracy.
Arie de Muynck
