> yes after changing html and cgi i rum makefsdata. but maybe i chose a
> wrong way. i thought cgi calls funktions a(prinz_stats),b
> (file_stats) and c (tcp_stats)form cgi.c. so i included a fuktion
> called "d" for my counting and this is not in folder fs. but Rowley
> CrossStudio compiled and downloaded it to ARM uC.
> So cgi part of new fsdata.c should call my funktion "d"
> But the cgi webpage is not found
There are two components to the cgi functionality
- the cgi script itself which is built into the file system by use of
makefsdata.
- the function that is called by the cgi script which is compiled as part of
the code.
Here is a basic example.
1) Generate a new cgi script that calls function d. Lets call this cgi
script test, so it is saved in a file called test (no extension) in the
directory uip/fs/cgi. This script transmits the text "this text is
transmitted" then calls function d.
script start-----------
t <html><head></head><body>
t this text is transmitted
c d
</body></html>
script end-----------
The line "c d" is where function d is called.
2) Write function d. The function name is going to be called CGI_tx() and
will just transmit the text "this text is coming from the function".
Write the function in the file uip/cgi.c.
function start--------
#define TX_TEXT "this text is coming from the function"
static u8_t CGI_tx( u8_t next )
____uip_send( TX_TEXT, strlen( TX_TEXT) );
function end--------
3) Place the function in the CGI function list array as follows:
cgifunction cgitab[] = {
print_stats, /* CGI function "a" */
file_stats, /* CGI function "b" */
tcp_stats, /* CGI function "c" */
CGI_tx /* CGI function "d" */
4) Run makefsdata - this will compile the cgi script generated in step 1
into the file system.
5) Compile your program.
6) Run program and brows to http://aa.bb.cc.dd/cgi/test
Richard.
http://www.FreeRTOS.org
