Lpc2000
( make -k clean ) problem with Eclipse/Cygwin/cdt
2005-11-21 by nealbrains
I am starting out with microcontrolles (LPC2131) and using eclipse
with cygwin and cdt (zylin).  I don't know if this is a problem or
not, but when I go to clean all the files through eclipse, i get
messages saying ------------
make -k clean all rm crt.lst main.lst crt.o main.o main.out main.hex
main.map main.dmp
rm: cannot lstat `crt.lst': No such file or directory
rm: cannot lstat `main.lst': No such file or directory
rm: cannot lstat `crt.o': No such file or directory
rm: cannot lstat `main.o': No such file or directory
rm: cannot lstat `main.out': No such file or directory
rm: cannot lstat `main.hex': No such file or directory
rm: cannot lstat `main.map': No such file or directory
rm: cannot lstat `main.dmp': No such file or directory
make: [clean] Error 1 (ignored)
 I don't know if the resulting hex file works because it was made for
a LPC2106 but I am in the process of configuring it for the LPC2131.
These example files and tutorial were from the pdf file by
James P Lynch "Arm cross development with Eclipse version 2"
Please feel free to send me any email if you have any info or help.
Thank you.
THank you,
Neal Dyrkacz
Re: ( make -k clean ) problem with Eclipse/Cygwin/cdt
2005-11-21 by rtstofer
main.hex
> main.map main.dmp
for
LPC2131.
> Thank you.
> THank you,
> Neal Dyrkacz
This is not an error and happens on every 'make clean'.  I use the
same platform, set up following the same tutorial, and it works
perfectly.
