Lpc2000
Nested interrupts
Nested interrupts
2005-11-23 by Marcio Zaquela
Hi guys,
I´m using nested interrupts and it is working fine when I run my code at RAM (MEMMAP = 2).
When I try to run my code at FLASH I receive a data or prefetch abort exception.
I´m using IAR compiler and the keyword __nested to declare my interrupt function.
If I declare my interrupt function without the __nested keyword everything runs ok.
Does anyone had any similiar problem ?
Re: [lpc2000] Nested interrupts
2005-11-24 by 42Bastian Schick
Marcio
> RAM (MEMMAP = 2).
> exception.
> function.
> everything runs ok.
Did you look at the code ? Did you set a breakpoint in your interrupt
routine
and look what's going on ?
42Bastian Schick
2005-11-24 by Marcio Zaquela
Hi there,
The problem is solved, I needed to increase the size of the stack when
running at Flash.
To: <lpc2000@yahoogroups.com>
Sent: Thursday, November 24, 2005 1:11 PM
Subject: Re: [lpc2000] Nested interrupts
Marcio
> I�m using nested interrupts and it is working fine when I run my code at
> RAM (MEMMAP = 2).
> exception.
> I�m using IAR compiler and the keyword __nested to declare my interrupt
> function.
> everything runs ok.
routine
42Bastian Schick
