Lpc2000
Vbat on LPC2138
Vbat on LPC2138
2005-11-24 by Sebastien Jacquemard
Hello,
I just would like to know if a lithium cell connect to Vbat on a LPC2138 save only the RTC or if it also save the SRAM contents ?
Sebastien
Re: Vbat on LPC2138
2005-11-24 by seangra
The Vbat is strictly for the RTC.  In low power power-down mode the
SRAM contents are preserved, but around 60uA of power is drawn from
Vdd.  I suppose it would be possible to have your lithium battery with
latch to a transistor to Vdd.  That way you could dynamically set the
latch to enable power from Vbat to Vdd, then place the processor into
low-power shutdown mode, and when you resume clear the latch to remove
the battery from the circuit.  Depending on your battery voltage a
simple diode may also work, but you'll need to be careful in how you
handle that to ensure that you don't try to remain on via lithium
battery voltage.  If you wanted to do something like this then having
a removable coin-cell lithium is probably your best bet so that you
can replace it when it runs out :)
--- In lpc2000@yahoogroups.com, "Sebastien Jacquemard"
<sejacquemard@w...> wrote:
> Hello,
> Thanks,
> Sebastien
Re: [lpc2000] Re: Vbat on LPC2138
Thank you.
Sebastien
To: <lpc2000@yahoogroups.com>
Sent: Thursday, November 24, 2005 8:37 PM
Subject: [lpc2000] Re: Vbat on LPC2138
> > Hello,
> > Thanks,
> > Sebastien
Re: Vbat on LPC2138
2005-11-25 by philips_apps
> Hello,
> Thanks,
> Sebastien
Vbat on the LPC2138 and LPC2148 keeps only the RTC alive. To keep the
SRAM up, you need to go into power down mode with a voltage connected
to Vdd.
On the new LPC2101/2/3, Vbat can also buffer the SRAM.
Regards, Robert
