Lpc2000
link q's
link q's
2005-12-05 by Steve Franks
Hi all,
fyi: I'm using WinARM, not a home-built distribution.  I think WinARM's
fantastic, btw.
So, I'm getting the following errors that I can't get rid of:
C:\projects\arm\examples\knightrider/main.cpp:41: undefined reference to
`SetNativeSpeed(unsigned long)'
C:\projects\arm\examples\knightrider/main.cpp:48: undefined reference to
`ioctl(int, unsigned long, void*)'
Obviously, my makefile can locate newlib-lpc, but I'm tearing out my hair
trying to fix it.  I've tried "-lnewlib-lpc" linker option,
vpath %.o C:\WinARM\arm-elf\lib
vpath %.a C:\WinARM\arm-elf\lib
and
-LC:\WinARM\arm-elf\lib
And nothing works.  I have no idea how the linker points to the lib dirs,
because I didn't originally see lib dirs pointed to anywhere in the makefile
like include dirs are.  Where's that magic?
Obviously, I'm not a make expert.  Apologize if this is question has an easy
answer that I could look up somewhere...
Steve
Steve Franks, KE7BTE
Electrical & Firmware Engineer
Tucson Embedded Systems
Re: [lpc2000] link q's
2005-12-06 by Robert Adsett
I hope this gets through, I've not been having much luck recently.
At 03:39 PM 12/5/05 -0700, Steve Franks wrote:
>Hi all,
>fantastic, btw.
OK, I would expect that was likely to work.
A question.  Where is your newlib-lpc archive?  You should find
libnewlib-lpc.a somewhere if you expect -lnewlib-lpc to work.
The linker control file has the ability to specify search path and that can
be used to supply path's if ld doesn't appear to be searching for the
archive correctly.  Something like
SEARCH_DIR( /home/radsett/arm/lib)
SEARCH_DIR( /home/radsett/install/arm-elf/lib)
SEARCH_DIR( /home/radsett/install/lib/gcc-lib/arm-elf/3.3.2)
Someone familiar with winarm can probably tell you what its search path
are.  It should have some built in to it.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2005-12-06 by Tom Walsh
Steve Franks wrote:
>Hi all,
>fantastic, btw.
The GNU linker does not do circular resolution of symbols, for example,
symbol foo is in 'libbar.a', when linking in with the 'libjunk.a'
archive, this would fail to give libjunk.a resolving of 'foo':
INPUT ( -lbar -ljunk )
This would solve the problem:
INPUT ( -lbar -ljunk -lbar )
GNU ld links "forward" resolving against successive objects to resolve
symbols, it does not consider previously known references that may have
appeared in proir objects (libs, *.o).   This may sound "wrong" but
there are many situations where this behavior is desirable (to overload
a known symbol such as your own version of strcpy() for example).
>and
>Steve
>Yahoo! Groups Links
RE:link q's
2005-12-07 by Steve Franks
> Message: 1
>    Date: Mon, 5 Dec 2005 15:39:34 -0700
>    From: Steve Franks <stevef@...>
> Subject: link q's
> Hi all,
> reference to
> reference to
I thought everyone would like to know the resolution:  when using newlib-lpc
from a .cpp file, one must surround the '#include' lines by 'extern "c" {}'.
Get's you every time.  Hopefully I'll save someone else a few hours someday.
'C' headers in cpp sources bites me about every 18 months.  One day I'll
learn...
regards,
Steve
Re: [lpc2000] RE:link q's
2005-12-08 by Tom Walsh
Steve Franks wrote:
>>Message: 1
>>Subject: link q's
>>Hi all,
>>reference to
>>reference to
>learn...
Maybe get an open source lint program and change it to look for that for
you?
TomW
