drive FRAMs of Ramtron
2005-12-07 by tastingfan tastingfan
Does anyone here drive FRAMs of Ramtron? My idea is descreibed as following:
One byte (0xb0) is written into FRAM with the function ‘Write_FRAM_Byte()’, ‘Read_FRAM_Byte()’ reads out this byte and sends it to the UART0 interface (UART0_SendByte()). But this program does not work at all, that is, there is no output to the UART0. I don’t know whether the problem is related to the write process or the read process. I am using LPC2131 and FM25CL64 of FRAM.
Thank you
Xia Shang
#include "config.h"
#define FM25L64_CS (1 << 29) //P0.29 is Chip Select port
#define ADDRESS_START 0x0123 // address of FRAM
#define WREN 0x06 // command of FRAM
#define WRITE 0x02 // command of FRAM
#define READ 0x03 // command of FRAM
#define WRITE_ENABLE MSPI_SendData(WREN)
#define WRITE_DATA MSPI_SendData(WRITE)
#define READ_DATA MSPI_SendData(READ)
#define UART_BPS 9600 // baudrate of the UART
// initializing the SPI
void MSPI_Init(void)
SPCCR = 0x52; // clock divider of SPI
SPCR = (1 << 3) | // CPHA = 1
(1 << 4) | // CPOL = 1
(1 << 5) | // MSTR = 1
(0 << 6) | // LSBF = 0
(0 << 7); // SPIE = 0
// send process of SPI
void MSPI_SendData(uint8 data)
SPDR = data;
while( 0 == (SPSR & 0x80)); // wait for SPIF until the data is finished
// write process of SPI
void Write_FRAM_Byte(uint16 address,uint8 data_write)
IO0CLR = FM25L64_CS; //select FM25CL64
WRITE_ENABLE; // WREN
WRITE_DATA; // WRITE
MSPI_SendData((uint8)(address>>8)); // high address
MSPI_SendData((uint8)address); // low address
MSPI_SendData(data_write); // data
IO0SET = FM25L64_CS;
uint8 MSPI_ReadData()
uint8 temp,status;
while(0 == (SPSR & 0x80));
status = SPSR;
temp = SPDR;
return(temp);
// read process of SPI
uint8 Read_FRAM_Byte(uint16 address)
uint8 data_temp;
READ_DATA; // send 'READ'�R
data_temp = MSPI_ReadData();
return(data_temp);
void UART0_Init (void)
uint16 Fdiv;
U0LCR = 0x83; // DLAB=1
Fdiv = (Fpclk / 16) / UART_BPS; // setting the baudrate
U0DLM = Fdiv / 256;
U0DLL = Fdiv % 256;
U0LCR = 0x03;
void UART0_SendByte (uint8 dat)
U0THR = dat;
while ((U0LSR & 0x40) == 0); // waiting, until data is finished
int main (void)
uint8 i, temp;
PINSEL0 = 0x00005505; // selecting SPI and UART0
PINSEL1 = 0x00000000;
IO0DIR = FM25L64_CS;
MSPI_Init();
UART0_Init();
while(1)
Write_FRAM_Byte(ADDRESS_START,0xb0);
temp = Read_FRAM_Byte(ADDRESS_START);
UART0_SendByte(temp);
return 0;
赶快注册雅虎超大容量免费邮箱?
http://cn.mail.yahoo.com
