Lpc2000
USB to RS232 adapter for Flash ISP Ultility downloads?
2005-12-08 by Joerg Schulze-Clewing
Hello,
Downloading to boards such as Keil's MCB2103 via the Philips flash
utility requires an RS232 port. However, most new laptops don't have
one these days.
In a post a while ago I read that one of the forum members (Varuzhan)
did this but it wasn't with the newer LPC2103. So, is it likely that
any USB-RS232 adapter could work or do I have to get a particular version?
I am asking because this is a tough issue with other uC. For example,
the JTAG interface for the MSP430 won't work with RS232-Parallel
adapters even though some adapter vendors claim 100% compatibility.
Regards, Joerg
http://www.analogconsultants.com/
Re: [lpc2000] USB to RS232 adapter for Flash ISP Ultility downloads?
2005-12-08 by David Hawkins
Joerg Schulze-Clewing wrote:
> Hello,
> one these days.
Hi Joerg,
I've used several USB-RS232 adapters. Both have the Prolific PL2303
chipset in them. The adapters are about $10 each.
I purchased several from TigerDirect.com.
One was a Belkin, the other was a Sabrent.
I just went to TigerDirect and searched for 'USB RS232';
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=USB+RS232&image1.x=0&image1.y=0
The Sabrent is the second item - $12.99.
The adapter works fine with LPC boards under Windows XP and
Linux (2.6 kernels).
Cheers
Dave
2005-12-08 by Rob Jansen
Joerg,
any USB-RS232 adapter will work, downloading only uses a standard UART
protocol (115200 baud, 8 bits, no parity, 1 stop bit, no handshake). I
have used two different USB-Serial adapters myself - no brand or product
name detected on both of them ...
Some development board may use the modem control signals to reset the
lpc and ty P0.14 low. The serial cable should support modem signals for
this.
Only problem I have is that sending full speed 115200 baud serial data
from LPC to my laptop may crash the driver of the USB cable.
Most likely a reinstall of my driver will be the solution for this.
Indeed, parallel port USB adapters won't work. The wiggler software
needs direct access to I/O pins for this.
I tried something using the FT245 from FTDI but this results in very
slow communications - the FT245 can bit-bang on high speed if only
output or input is needed but when you have some input and some output
signals you'll have to wait for the next USB packet to be sent (1 ms
interval).
I am still working on my LPC2138/Ethernet based debugger pod - it should
support RDI so that it can be used with gdb/insight and commercial tools
like SDT/RealView.
(Are there still laptop without Ethernet interface ???)
Still having problems with single step/run though ... (need more input
on the way TAP works and the exact connections to the E-ICE module).
    Rob
> Hello,
> one these days.
> Regards, Joerg
Re: USB to RS232 adapter for Flash ISP Ultility downloads?
Hello David,
Thanks. That gives me hope. I may have to order it as you did since
even the local computer stores do not carry USB-RS232 adapters of any
kind. Which I find a bit strange. Well, maybe too many people have
thrown away their old serial stuff by now.
I was hoping that at least Radio Shack would have one but I pulled a
blank on their web site. I think that the places that sell kits like
the Keil eval board should offer those converters so the
RS232-deprived could simply add it to the order. Kind of like how a
gas station will also sell snacks.
Regards, Joerg
Hello Rob,
product
Thanks for the info. Guess I have to get an adapter then. At least the
newer ones should be able to do 115200 baud.
Regards, Joerg
2005-12-09 by Peter Homann
Hi Joerg,
The USB to RS232 or Parallel port converters don't retain any timing data.
The Phillips flash utility uses a standard serial RS232 interface so it
will work.
The MSP is using the serial interface but is probably using the control
signals for non serial control. If there is any timing required, it may
be lost by the USB to serial converter.
This is similar for programs that use the parallel port to control
stepper motor drivers. The generated pulse streams are time critical.
The USB-parallel converters don't give a stuff about the timing issue,
and so the timing data is lost.
Peter.
> Hello,
> one these days.
> Regards, Joerg
Web:   www.homanndesigns.com
email: homann@...
Phone: +61 421 601 665
www.homanndesigns.com/ModIO.html         - Modbus Interface Unit
www.homanndesigns.com/DigiSpeedDeal.html - DC Spindle control
www.homanndesigns.com/TurboTaig.html     - Taig Mill Upgrade board
2005-12-09 by Rob Jansen
Another program is the USB timing. USB 1.1 has a 1 ms packet timing and
USB 2 a 128 us timing.
This means that combined reading writing (e.g. set CLK, read MISO, clr
CLK) will cost you 3 packets.
That's 3 ms on USB 1.1 and .375 ms on USB 2.
I tried using the FT245 as SPI/ISP port but stops my efforts when I
discovered this.
FT245 is great if you're only doing output (or input) you can even
specify a timing.
Rob
