Lpc2000
Zylin CDT installation
2005-12-12 by householder_lpc
I've been trying to get the Zylin CDT to work on Eclipse, but my
attempts have been futile. As Jim Lynch wrote in his book, and as is
written on the Zylin site, I've extracted the two zips to the eclipse
directory.
I can now see some new maps under the features and plugins submaps of
Eclipse. When I startup Eclipse though, there is nothing about C/C++
to be seen. Jim Lynch says that, when you do File>new>Project, you
should see C and Cpp options. I don't get this.
Has anyone encountered a similar problem? Should I also do something
in Eclipse or change some config files?
The archives I used were:
eclipse-SDK-4.1.1-win32.zip
embeddedcdt-20051102.zip
zylincdt-20051102.zip
Re: Zylin CDT installation
2005-12-12 by lynchzilla
--- In lpc2000@yahoogroups.com, "householder_lpc"
eclipse
> directory.
of
I got this e-mail a couple of days ago from Eelco Duivenstijn that
might be the answer. I haven't investigated it yet since I've just
finished my latest tutorial revision this weekend. Take a look.
Jim Lynch
To: lynchzilla@...
Sent: Wed, 7 Dec 2005 17:10:21 +0100
Subject: ARM Cross Dev. With Eclipse V2
Dear Mr. Lynch,
Finding my way into the ARM world I stumbled across your amazing
piece of work dealing with ARM cross development using Eclipse.
It's the best support you could dream of as novice startting in this
puzzling world of hardware and support tools. My true compliments.
While stepping through your installation description I ran into a
nasty problem I couldn't understand at first (being a novice anyway).
After installation of the Zylin zip's the CDT plugin didn't show-up
in the Eclipse window. Spending several hours of searching it turned
out to be that CDT has been disabled (by default seemingly) in the
Product configuration window. Enabling is all that's required to run
it as expected.
A minor suggestion is to change the comment lines in the linker
command file for the RAM version of BLINK2106 as it states there that
startup and text go into FLASH while RAM is meant.
I hope others might benefit from these suggestions.
Thanks for the help that you've provided with your publication which
was absolutely beneficial to me !
With kind regards,
Eelco Duivenstijn
Re: Zylin CDT installation - solution
I found the solution to my own problem. Eclipse didn't find the
cdt-"feature", because it was not the right version. The version of
the plugin was org.eclipse.cdt_3.1.0, while all the other plugins were
3.1.1.
So I changed the name of the map for this plugin to 3.1.1, and now,
everything seems to work fine.
This may or may not be the most catholic approach, but it worked and I
thought I'd share it for posteriority.
