Lpc2000
GCC - locals performance
2005-12-14 by xjag74
I wonder which kind of implementation well be performed faster using
GCC:
void functionname(void)
  unsigned char x=0;
  unsigned char y=1;
  unsigned char z=2;
  ...Do something with x,y and z.
or
  unsigned long x=0;
  unsigned long y=1;
  unsigned long z=2;
The first example uses less stack, but it takes a longer time for
initialization when calling the function cause the 8 bit have to be
masked out.
Am I right with that supposition?
regards
xjag
Re: GCC - locals performance
2005-12-14 by brendanmurphy37
The short answer is that it is impossible to say what either version
does without looking at the assembler output from the compiler at
the particular optimisation level you are using.
For example, at anything other than no optimisation, there's a fair
chance no stack space will be used in either version, as the
variables can be kept in registers.
At high optimisation levels, for anything other than very trivial
functions, you'll have a tough time following what's going on. GCC
does a pretty good job of optimisation, but the cost is that it is
difficult to relate back to the source.
As a (very) general rule, unless there's some specific (usually
space saving) requirement, on most processors and most compilers,
using "int" or "unsigned int" will give the most efficient results.
However, there's so many exceptions to this (e.g. int size of 32-
bits reading/writing across a 16-bit bus) that it's almost not worth
bothering with.
By far the most important point I'd make is: "why do you care?".
Unless the function in question is in the innermost part of a loop
executed very many times, or is part of a very high frequency
interrupt handler, I'd be willing to guess it has no effect on your
system's performance.
Brendan
--- In lpc2000@yahoogroups.com, "xjag74" <detlef.weidner@w...> wrote:
> Hi,
using
> GCC:
>   unsigned char x=0;
>   unsigned char y=1;
>   unsigned char z=2;
> or
>   unsigned long x=0;
>   unsigned long y=1;
>   unsigned long z=2;
be
> masked out.
> regards
> xjag
Re: [lpc2000] GCC - locals performance
2005-12-16 by 42Bastian Schick
xjag74 <detlef.weidner@...> schrieb am Wed, 14 Dec 2005 14:51:16
-0000:
>   unsigned char x=0;
> or
>   unsigned long x=0;
> masked out.
Both version use the same amount of stack since the stack must be 4 byte
aligened on a ARM7.
The unsigned char version will in many cases need more instruction with gcc
because it often does a 8->32 bit promoting (although a ldrb would
suffice).
My hint: Look at the assmbly output (-S option for gcc) !
42Bastian Schick
