Lpc2000
Un-aligned data access on ARM7 core
2005-11-16 by Marko Panger
Hello all,
I have a general programming question. Me and my co-workers had an
discussion about data alignment and non-aligned accesses. Please
consider the following situation where an un-aligned access was made
resulting in wrong value.
char buf[5] = {1,2,3,4,5};
unsigned short tmp;
tmp = *(unsigned short*)&buf[1];       /* &buf[1] is on a odd address
My co-workers expected that tmp will contain the value0x0203, but the
value was 0x02. I understand that, because ARM7 core does not support
un-aligned accesses and the compiler was forced to use a word access on
a odd address. This code was ported from an 8-bit machine where it was,
off course, working. My question is if all 32-bit devices would have the
same problem with this code and why when we tested the same situation on
a PC using Borland Builder compiler it was working as my co-workers
expected. Is this a CPU(+cpu bus) issue or it is also compiler dependent.
Although I thing this is bad programming practice and it calls for
errors I am asking if it is possible to enable a warning for such
situations.
Marko
2005-12-16 by Marko Panger
Hello all,
unsigned short tmp;
situations.
Marko
Re: [lpc2000] Un-aligned data access on ARM7 core
2005-12-16 by Tom Walsh
Marko Panger wrote:
>Hello all,
>unsigned short tmp;
X86 is about the only 32bit processor that I know of that will access
longs / words on uneven boundries.  Almost all other families of 32bit
processors have the limitation of accessing longs / words on their
respective boundries.  The X86 is the oddball of the computer world.
TomW
>situations.
>Regards,
>Marko
>Yahoo! Groups Links
2005-12-16 by Richard
When you use an explicit cast, you are telling the compiler that you know
what you are doing and the compiler should leave you alone, so that's what
it did. For example, if you always ensure that the buf starts at an even
address, and that you only do things like
         tmp = *(unsigned short *)&buf[i];
where i is even, then the warning would be unnecessary.
Bottom line - casts should not be used willy nilly without fully
understanding what's happening.
At 01:17 PM 11/16/2005, Marko Panger wrote:
>Hello all,
>unsigned short tmp;
>situations.
>Regards,
>Marko
// richard (This email is for mailing lists. To reach me directly, please
use richard at imagecraft.com)
2005-12-17 by Robert Adsett
>unsigned short tmp;
Compiler, micro and possibly more could play a role.  ANSI and ISO give the
compiler leeway to do just about anything at this point.  Some micros will
have a bus fault, some will read the incorrect value and some will read the
'correct' value.  Note that whether the problem shows up may also depend on
what else is in memory since the compiler is certainly free to place buf
such that it starts on an odd address at which point buf[1] is suddenly on
an even address.  Of course on a recompile it might change.  All of a
sudden you have yourself a Heisenbug.
The correct value at this point is also open to question even if alignment
isn't an issue since that still leaves byte ordering and that varies across
micros.
>situations.
Yes, but the cast will likely trip you up.  PC-Lint gives me a warning
about a cast from a pointer to a pointer but  that is probably not a
sufficient warning.
Depending on what you are trying to do there are alternatives that will
work reasonably portably.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2005-12-17 by Marko Panger
Your replies are just what I was looking for. I needed a confirmation of
my understanding and I got it. For me, is normal not to receive a
warning in this situation because the compiler was forced by you. And
yes, different micros will react differently. Some will issue bus error,
some will read incorrect value and so on. My co-workers claimed up on
the micro and compiler that this should be handled but I really can't
imagine how if the compiler was forced.
This code was ported from an 8 bit machine (with 8 bit data bus) when
such things works regardless of "buf" alignment, because buf is accessed
every time 8 bit, regardless of the cast.
The only thing that I was surprised was my PC box where this was possible.
My conclusion is that un-supported un-aligned accesses are not
compiler/cpu bug but are compiler/cpu FEATURE and a skilled programmers
should RTFM and be aware of this.
Thanks for you replies !
marko
>>unsigned short tmp;
>micros.
>>situations.
>sufficient warning.
>Robert
>Yahoo! Groups Links
2005-12-17 by Tom Walsh
Yeah, reminds me about something I did with a cast recently to extract a
long from char array (buffer).  I cast the heck out of that reference to
the char array and gcc did let me extract a long from it..  On an uneven
boundry, the processor (LPC2138) didn't throw an exception, but it sort
of got "a value" from the array, but the not the value I was expecting!
Heh, the upper byte (MSD) was, how shall I say it, "wrong". heh
I learned my lesson about coercing gcc + ARM to do some things with type
casts.  Now I'm a little more conservative about how I cast references
to objects.
TomW
>>Hello all,
>>unsigned short tmp;
>>situations.
>>Regards,
>>Marko
>Yahoo! Groups Links
Marko Panger wrote:
>Hi,
Yes, you can do that too with the ARM processor, but you describe that
type of data as "__attribute__((packed))"  to signal the compiler to
treat the structure differently.  With a 'packed' attribute, the
accesses to various parts of the structure may be done on a long, word
by word, or byte by byte basis, depending.
TomW
>marko
>>>unsigned short tmp;
>>micros.
>>>situations.
>>sufficient warning.
>>Robert
>>Yahoo! Groups Links
>Yahoo! Groups Links
PCs and PC programmers tend to allow and encourage a lot of things that are
very bad practice in the embedded world.  Arguably they are bad even in the
PC world but the costs are low.
Yep, and one thing I didn't point out earlier is that your example also
appears to depend on the sizes of both char and short which are not
guaranteed to be specific sizes.  They often are 8 bits and 16bits
respectively but both can be larger.
Robert
