Lpc2000
Linker Problems
Linker Problems
2005-12-19 by miruffer
I have big problems with the gcc-linker. Last week I compiled the
newest version of gcc(4.0.2), binutils(2.16.1) and newlib(1.13) under
linux debian. Before I worked with WinARM(gcc 4.0.0).
I tried to compile my project with the new toolchain. No warnings no
errors. But the printf didn't work. To let the printf work via uart1 I
have initialized it and have rewritten some function of the libc:
_write_r and _read_r. Everything works well with WinARM. Now I looked
in the assembler code compiled with the new toolchain and the linker
has used the _write_r from libc and not my new one.
Can I force the linker to use my new one?
thanks, miru
Re: [lpc2000] Linker Problems
2005-12-19 by Tom Walsh
miruffer wrote:
>Hi,
Sure, get a large hammer...  I would look to your library itself, you
have to turn on some options within newlib to compile it out into stubs
for some of the I/O code.  Take a look at the scripts I use to build my
development environment with, I use the newlib stubs to do char I/O from
the library:
http://www.openhardware.net/?title=ARM%20Thumb%20tools%20for%20LPC2000&dir=ArmTools&file=ThumbToolchain.html
TomW
Re: Linker Problems
2005-12-21 by miruffer
thank you for your answer. I look at your scripts and have seen that
you use the flag --disable-newlib-supplied-syscalls. I have rebuilt my
GNU Toolchain.
When the linker links my project, there are the errors shown below.
/opt/arm-tools/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib/libc.a(writer.o):
In function `_write_r':
../../../../../newlib-1.13.0/newlib/libc/reent/writer.c:58: undefined
reference to `_write'
/opt/arm-tools/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib/libc.a(closer.o):
In function `_close_r':
../../../../../newlib-1.13.0/newlib/libc/reent/closer.c:53: undefined
reference to `_close'
/opt/arm-tools/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib/libc.a(fstatr.o):
In function `_fstat_r':
../../../../../newlib-1.13.0/newlib/libc/reent/fstatr.c:62: undefined
reference to `_fstat'
/opt/arm-tools/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib/libc.a(lseekr.o):
In function `_lseek_r':
../../../../../newlib-1.13.0/newlib/libc/reent/lseekr.c:58: undefined
reference to `_lseek'
/opt/arm-tools/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib/libc.a(readr.o):
In function `_read_r':
../../../../../newlib-1.13.0/newlib/libc/reent/readr.c:58: undefined
reference to `_read'
/opt/arm-tools/lib/gcc/arm-elf/4.0.2/../../../../arm-elf/lib/libstdc++.a(eh_personality.o):
All the functions he can't find, are exsisting in my own libary the
linker had opend before. I can't understand that.
thanks miru
In function `base_of_encoded_value':
--- In lpc2000@yahoogroups.com, Tom Walsh <tom@o...> wrote:
> miruffer wrote:
> >Hi,
from
> the library:
> Regards,
> TomW
Re: [lpc2000] Re: Linker Problems
2005-12-21 by Tom Walsh
miruffer wrote:
>Hi,
>GNU Toolchain.
Absolutely correct.  You've done it the right way.  Now, if you want to
know what can be done with those missing routines, also get a copy of
the RDCF2 filesystem source (also from my site).  *You* provide those
functions: write_r, open_r, etc..
When you compile newlib, without the stubs, it assumes that it will be
dealing with an operating system which would provide a call entry
structure to perform device I/O.   Since you are not using an operating
system, such as Linux, you have to provide that last bit of code to
bridge between the library (abstraction) and your hardware (reality).
The newlib, nor any library, is intended to provide a "final solution".
They cannot, hardware varies from environ to environ.  It is up to you,
ultimately, to see that the "operating system" provide a means to move
the data stream coming out of the library over to the hardware.  With
something like Linux, we do this be means of the various hardware driver
code and the SysCalls.  When you don't have an operating system, the
same requirement still exists to physically connect the data stream from
the library to the hardware.
This is what the RDCF2 code is about.  It illustrates how to do device
(hardware) interfacing to newlib, so that you can use filestreams such
as: fopen(), fread(), fwrite(), fgetc(), etc..  I only provided code to
interface to an SD drive.  The application that I'm building does not
require, nor tolerate, file streams to the serial port(s).  Having said
that, you can add a device "UARTx" to the device table, then add another
file identical in structure to that of 'mmc_module.c'.  Take a look at
that file, at the bottom is the DEVICE_TABLE_ENTRY struct which provides
the entry points to get work done.  This is the "final link" between
newlib and the hardware.  The write_r, read_r, open_r code I provide is
the mechanism to handle multiple data streams and to direct those
streams to the various hardware.
I had taken a general purpose approach to implementing the stub code.
There are two key elements of the interfacing process: adding a new
device to the DeviceTable array, adding a new module which contains the
implementation of the device entry.  The code in between, all those
ending in "*_r.c" do not need to be altered.
1. devices.c contains the device table.
2. sysdefs.h contains the device IDs.
3. mmc_module.c illustrates the implementation of the device.
You simply add your new module code and make an entry into the device table.
I see that this may be confusing to a first time user of libraries on
embedded systems.  All embedded system libraries function in essentially
the same manner.  Ultimately, there has to be "bridging code" written by
the end-user to provide a link between the hardware and the library.
While you could get deep inside the guts of newlib and hack your way
into getting the write() function to give you an output you desire, I
would advise against it.
TomW
miruffer wrote:
>Hi,
>GNU Toolchain.
This may explain a bit better how newlib stubs operate:
http://www.openhardware.net/?title=Newlib%20stub%20interface&dir=rdcf2&file=newlibstubs.html
TomW
Re: Linker Problems
thank you very much for your explanation and the provided source code,
but I think you misunderstood me. I have written the routines _write_r
and _read_r and so on. I compiled these new written functions and
build my own small library called libosarm.a . If I disassemble this
library there is the correct assembler code inside. But if I link my
project with arm-elf-gcc $FLAGS -o tst *.o -Wl,-verbose -losarm I can
see that the linker opens my library, but after that he opens libc.a
and shows the errors.
regards, miru
> miruffer wrote:
> >Hi,
> >GNU Toolchain.
solution".
driver
from
another
provides
device table.
essentially
written by
> TomW
Re: Linker Problems
2005-12-21 by rtstofer
> TomW
Tom,
Great explanation!
Richard
miruffer wrote:
>Hi,
Then try this:
arm-elf-gcc $FLAGS -o tst *.o -Wl,-verbose -lc -losarm
Tell it to link in libc, then libosarm.  It should then link in libc,
then look to subsequent libraries to resolve the missing references for
libc.  The linker works from left to right, symbols unresolved at that
point, are found only in subsequent libraries, not in the the previous
ones.  I have abandoned the use of code archives in my project because
the linking order got too wacky:
INPUT( -lc -lsystem -lc -liface -lc -lmmc -lc -luarts -liface -lc -lstdc
-lgcc );
At that point, I felt there must be a better way! :(   There was,
eliminate all those stupid archives.  But, then I was faced with the
problem of how to build a list of object modules to link together.  This
is my project tree:
EvntCPU/
|-- facp
|   |-- datatest
|   `-- include
|-- iface
|   `-- include
|-- include
|-- mmc
|   `-- include
|-- setup
|   |-- include
|   `-- menuSrc
|-- system
|   `-- include
|-- uarts
|   `-- include
`-- upgrade
There are 73 object files that need to be link, these mostly in the
child directories off the project root.  What I needed to do was have
something that told gcc to link all the object files.  But the only way
I could think to do this was to give a list of all of them, complete
with path/object.o references.  The solution to that is in the Makefiles.
================== project Makefile ===================
export LINKOBJS=.linkobjs
MODULE_DIRS = setup iface system facp mmc uarts
# Default target.
all: announce buildModules build
announce:
   @echo "** Building EVNT(2138)"
buildModules:
   @rm -f $(LINKOBJS)
   @for subdir in $(MODULE_DIRS) ; do \
      $(MAKE) -C $$subdir ; \
   done
build: elf bin lss sym
=============== end ===================
As each of the MODULE_DIRS are built, the append a list of object files
into the main list.  This file is then used when linking.  Here is how I
create that list of objects within each MODULE_DIRS:
========== subdir Makefile ======================
ifndef $(PROJSUBDIR)
PROJSUBDIR=$(shell /bin/pwd)/../
endif
CURSUBDIR=$(shell /bin/pwd | sed 's:/.*/::')
DEPEND=$(PROJSUBDIR)/.depend
SRCS := $(wildcard *.c)
OBJS := $(patsubst %.c,%.o,$(SRCS))
LOBJS := $(patsubst %.c,$(CURSUBDIR)/%.o,$(SRCS))
all: announce $(OBJS) finish
finish:
   echo -n "$(LOBJS) " >> ../$(LINKOBJS)
announce:
   @echo "   Building iface"
%.o: %.c
   $(CC) $(EXTRAINCS) $(THUMB) $(THUMB_IW) $(OPTNONE) $(ALL_CFLAGS) -c
$< -o $@
   touch $(DEPEND)
=========== end ========================
LOBJS is the key.  When the finish rule is run, it appends to the main
list all the object files with the current dir.  This occurs  for each
and every MODULE_DIRS dir.  Ultimately, back at the main project
Makefile we link everything to make the elf file:
==============  project Makefile =====================
%.elf: $(OBJ) $(DEPEND)
   $(CC) $(OPTNONE) $(ALL_CFLAGS) $(OBJ) --output $@ $(LDFLAGS) `cat
$(LINKOBJS)`
=============== end =======================
Note the backticks surrounding the cat $(LINKOBJS), effectively the
contents of the file containing all those object filenames we collected
appear there.   Also notice the $(DEPEND), that is used as a build flag
file.  When a subdir compiles a new object file, it touches (dates +
time) the depend file.  Later, the depend file is used within the ELF
rule to see if linking is required (build a new elf image).
If you haven't mastered the Makefiles yet, do so.  It does take some
work to get them to make sense, but the ability to create / manipulate
your own make system is well worth the effort!  Especially if you plan
on continuing to do more than blink an LED.  ;-)
We don't need no stinkin' archives!
TomW
>>TomW
>Tom,
>Great explanation!
>Richard
Thanks Richard.  Knowledge is free.  I don't mind sharing knowledge as
most people don't know what it is that I'm talking about anyway, heh.  ;-)
TomW
>Yahoo! Groups Links
