Lpc2000
Question on I2C ACK (With EEPROM)
2005-12-23 by Sanjiwani
Hi Everyone,
I am facing one problem in My Project.
Should we read ACK (Acknowledgement) Signal from I2C?
Thanks In Advance.
Re: [lpc2000] Question on I2C ACK (With EEPROM)
2005-12-23 by Rob Jansen
Sanjiwani wrote:
>Hi Everyone,
You're using the exact correct word: should ...
It is not a must but there are some good reasons for checking the ACK.
Verifying the ACK makes sure that your I2C device still exists and that
you are reading and/or writing the correct data.
The hardware of the I2C controller will take care of this (and make sure
that you do not send a next byte before an ACK is received), but you
should in your software that the ACKs are indeed received.
I just browsed through the user manual but cannot determine at a glance
if it is possible to disable the check on the ACK or if there is a
timeout that can be set in hardware.
Please note, there are 3 different types of devices (seen from an ACK
point of view):
    1) Regular devices that always respons with an ACK immediately after
receiving the databits.
    2) EEPROM devices that may strech the clock by holding the ACK until
a programming cycle is complete
    3) special devices that never generate an ACK.
In this 3rd category you may find devices that have a "2 wire serial
interface". Due to licensing issues these devices are not marked as I2C
and may not generate an ACK pulse (but some do).
Also some LCD drivers that are marked as I2C may fall into this
category. I used some on-glass mounted devices that do not generate an
ACK because of power constraints.
Depending on "My Project" take care of the ACK:
If the end product is used to guard a petrol tank, I would flash lights
and ring a bell if the ACK fails.
For a petrol pump I would place a warning on the screen and possibly put
an "out of order" sign on the display.
For an I2C controlled printer on a POS, just continue without printing
tickets and let the operator ring the bells ...
Good Luck,
       Rob
2005-12-26 by Craig Schlenter
>  point of view):
> after
> until
Well the eeprom's I am familiar with (such as the 24LC515) simply don't
ack the
address byte at all if they are busy writing (i.e. you've just written
to it). Once they
are done writing (which is normally a few milliseconds), they start
acking again.
--Craig
