Lpc2000
Olimex LPC-P212X boards specifications erronous
2005-12-24 by gussabina
Hi:
I lost a long time trying to debug a simple program reading the
Buttons, in the Olimex LPC-P2124/9 boards. Finally, I discovered that
the buttons are not connected to the microcontroller at P0.15 and
P0.16, as the board information says. Instead, they use the P0.10 and
P0.11 pins
Jus in case, I downloaded the information again, but the errors still
there...And I downloaded an examples using the buttons using the P0.15
and P0.16 pins...Does the author of these examples test them???
Can someone confirm what I 'm saying? If so, it would be a great job
from Olimex, if they correct the board specifications...
Thanks
Gus
Re: Olimex LPC-P212X boards specifications erronous
2005-12-24 by rtstofer
--- In lpc2000@yahoogroups.com, "gussabina" <gussabina@y...> wrote:
> Hi:
that
and
> P0.11 pins
still
P0.15
job
> Thanks
> Gus
No surprise!  The LPC2106 board has the same problem.  The schematic
shows the button on P0.31 but it is connected to P0.15.
I don't trust their documentation at all.  But, the hardware works
fine and that's what I really care about.
I suspect there are hardware changes after the documents are
completed.
Richard
