Lpc2000
MSP430 Lower Power?
MSP430 Lower Power?
2005-12-30 by jlowryspectrum
My last project used an LPC2138.  My next project is battery powered
and must be able to sleep then wake up each hour.  From reading various
posts it looks like the LPC takes about 60-70uA when operating in deep
sleep with RTC enabled.
Anyone have experience with MSP430.  First glance thru their docs
indicate when in LPM3 (interrupts and timer enabled) it draws 2uA.  Is
there something else I should be aware?
Jeff.
RE: [lpc2000] MSP430 Lower Power?
2005-12-30 by Joel Winarske
LPC213x data sheet excerpt:
IBAT // Power-down mode supply current // VBAT
RTC clock = 32 kHz (from RTXC pins), Ta = +25 °C
VDD = 3.0 V, VBAT = 2.5 V - 14 - mA
VDD = 3.0 V, VBAT = 3.0 V - 16 - mA
VDD = 3.3 V, VBAT = 3.3 V - 18 - mA
VDD = 3.6 V, VBAT = 3.6 V - 20 - mA
You should be able to take advantage of this with a scheme like this:
1. Use RTC to generate desired hourly alarm interrupt
2. Set RTCWAKE bit in INTWAKE to enable alarm wake up
3. Power down part via PD bit in PCON
Perhaps there is variation in this for the LPC214x and the LPC2101/2/3.
Joel
Re: MSP430 Lower Power?
Thanks Joel for the reference.  You actually mean uA rather than mA.
I got the 60-70uA from "LPC213xpower.pdf" in the "files" area of this
group.  Jeff.
powered
various
deep
this:
LPC2101/2/3.
> Joel
2005-12-30 by lpc2100_fan
the difference is that 60-70 uAs is power down, keeping all the
information of the registers and 32k SRAM intact while the lower
values is RTC only from Vbat and the information from SRAM and
registers is lost but usually you can save the stuff into the Flash.
Now about MSP430 or LPC2138, well if you can deal with 62k Flash, 2K
SRAM and a max of 16 MHz which afaik is the max. configuration you can
get on a MSP430 today, then it is lower power in power down. You will
probably pay a similar price for for much lower performance and 1/8 of
the memory device.
So in a nutshell, you get a lot more for your money using the LPC2138
but the MSP430 has low power modes being most of the time not active
that are lower than those of the LPCs.
Hope this helps, Bob
> Jeff.
RE: [lpc2000] Re: MSP430 Lower Power?
> group.  Jeff.
Yes thanks for the correction.  I copied direct from pdf into Word, without
confirming the pasted data.
Corrected Table:
VDD = 3.0 V, VBAT = 2.5 V - 14 - uA
VDD = 3.0 V, VBAT = 3.0 V - 16 - uA
VDD = 3.3 V, VBAT = 3.3 V - 18 - uA
VDD = 3.6 V, VBAT = 3.6 V - 20 - uA
Joel
Re: [lpc2000] MSP430 Lower Power?
2005-12-30 by mucko
Hi,,
MSP430 family has really good at lower power modes,.I
have experinced with this family and used msp430f4xx
family of controllers in a metering application
projects.I can say the chip while working cpu clock of
8 mhz,125 nsec.,it draws only 5 uA even lcd is on, and
also all interrupts active!
this gives the greatest battery life!
regards,
--- jlowryspectrum <jlowry@...>
> battery powered
> operating in deep
> thru their docs
> it draws 2uA.  Is
> Jeff.
__________________________________________
Yahoo! DSL \ufffd Something to write home about.
Just $16.99/mo. or less.
dsl.yahoo.com
2005-12-31 by Mr shyam_Gopal Mishra
yes i m fully agried with mr mukadder .....its true
msp430 series is the ideally targeted for lowpower &
battery driven applications.....
rgds
Shyam
--- mucko <mukadder_c@...> wrote:
> Hi,,
> modes,.I
> of
> and
> regards,
> is
> > battery powered
> when
> > operating in deep
> > thru their docs
> enabled)
> > it draws 2uA.  Is
> > Jeff.
> dsl.yahoo.com
dsl.yahoo.com
2006-01-02 by Mauricio Scaff
Yes... If you need really low power, go to MSP430.
I have a MSP430F413 counting time, waking every second using about 1.8uA.
> Jeff.
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
