Philips appnote interfacing MMC to LPC2xxx
2006-01-05 by Micron Engineering
I read the application note, I have just a question: - SD and MMC implement a wear level mechanism or have I to provide a wear leveling algorithm by myself? Best regards. ---------- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.1.371 / Virus Database: 267.14.12/220 - Release Date: 03/01/2006 [Non-text portions of this message have been removed]
2006-01-05 by Tom Walsh
Micron Engineering wrote: >I read the application note, I have just a question: >- SD and MMC implement a wear level mechanism or have I to provide a >wear leveling algorithm by myself? > > Depends on whether you purchase the cheapest, "house brand", device or spend the money for a Sandisk / Lexmark. IIRC, Sandisk includes the wear leveling. From page 1-3 of the SanDisk document #80-36-00320: "1.8 Defect and Error Management ... In the rare case that a bit is found to be defective, the cards replace it with a spare bit within the sector header. If necessary, the card will replace the entire sector with a spare sector ..." As they say: RTFM, Read The Fine Manual. TomW -- Tom Walsh - WN3L - Embedded Systems Consultant http://openhardware.net, http://cyberiansoftware.com "Windows? No thanks, I have work to do..." ----------------------------------------------------
2006-01-05 by Sean
The end answer to your question is no, you do not need to implement this yourself, unless you really plan on hammering the card. Most SD cards these days have between 10,000 to 100,000 write cycles per sector. For example, assuming 100,000 cycles, if you updated a sector once per minute, 24 hours a day, you would exceed the rated life after 70 days. However if you wrote once per 10 minutes, you'd get 2 years out of it. As long as you don't use Flash like RAM I don't see why you'd need to write that often. Kingston cards seem to incorporate a built in wear levelling mechanism, and also bad block remapping facility, by reserving sectors similar to how a hard drive does it. SanDisk's SD manual states that on their devices the wear level command is equivalent to a NOP, since they have > 100,000 cycles. That information is from around 2003, so I assume it's still accurate. -- Sean At 09:33 PM 1/4/2006, you wrote:
>I read the application note, I have just a question: >- SD and MMC implement a wear level mechanism or have I to provide a >wear leveling algorithm by myself? >Best regards.
2006-01-05 by Sean
As a more definitive answer: The latest SanDisk product manuals can be found here: http://www.sandisk.com/Oem/Manuals/ Note the latest RS/MMC manual has no mention of wear levelling, but does mention the automatic bad sector remapping. The latest CF and SD documents explicity state that wear levelling is not required, but implemented as a NOP command for backwards compatibility. However other manufacturers may actually implement the command, assumedly if their # of write cycles supported is low. You may also find this interesting: http://www.sandisk.com/Assets/File/OEM/ApplicationNotes/MultiMediaCard/AppNoteMMCQAv1.0.pdf So basically the decision is up to you as to wether or not you want to implement your own wear levelling, however unless you're really hammering the flash I'd think it's not necessary. YMMV. -- Sean At 09:33 PM 1/4/2006, you wrote:
